Results 1 to 4 of 4
Thread: TA22 Speedo gone crazy
    Default TA22 Speedo gone crazy
    Just started the other day.Speedo needle bounces away when moving.If I am doing 60 the needle bounces between 60 and 80.Diffeent speeds but same result.Any help much appreciated.
    CHEERS
    Default Re: TA22 Speedo gone crazy
    your speedo cable is probably frayed inside the sheath, and the broken wire is catching.. causing the needle to jump as it lets go.
    pull out whole cable, and pull out center of cable to see if it is damaged.
    Aug 2006
    success 6164
    this happened to me aswell in my ae82..i pulled the dash out and sprayed white grease into/onto the cable..all was good after that.
    Thanks will try each of these tricks this week
  1. (TA22) 2T - 2TGEU conversion (now with pics)
    Last Post: 13-11-2006, 08:52 AM
