i personaly wouldn't do it, i had a non-p/s ra60 and it was terrible! my soarer is so much nicer![]()
Yes JDM only... & yes now landfill...Originally Posted by Vios-GT_07
RA60/5 parts will not fit without big mod's..
but on that, i can get tierod's made to fit the RA's rack, but have to mod cross member, & need shaft from rack to colum mod..
this also may need engineers report...
Project: '82, GA61 XX
Destroyer of 'Drop Forged' spanners
According to thisOriginally Posted by GA61XX
http://ourworld.compuserve.com/homep...o/newcodes.htm
That N is just the trim level of the car.
N - Mid level (general)
Doesn't necessarily mean it has manual assisted rack.
Nathan, what character is there on yours?
Have you gone to Toyota and checked the price/availability of the rack?
Does the EPC show us pictures by any chance? (I'm not near mine)
Would def require engineers report.Originally Posted by GA61XX
Wouldn't be a cheap one either.
Measurements of bumpsteer, ackerman angle, etc...
Would be a bastard to pass.
Finding a factory one would be mucho easier.
My shoulder my pain..Originally Posted by CrUZida
It's not the car.... it's power steering ..
RA40/60 manual steer & 5 speed = no pain..
Charger manual steer & 3 speed = no pain..
MA61 auto with power = pain..
That's a damn good question. If my car still had a build plate I'd tell you.Originally Posted by CrUZida
Crap!
Forgot about that![]()
"N" = lowest model. '81-'82 only. gaurd mounted mirrorsOriginally Posted by CrUZida
Manual steering was only optional on this model..
"S" = mid. '81-'85. eg. stick hand out of window to move wing mirror![]()
"G" = good stuff. '81-'85. eg. power wing mirrors![]()
"GT" = race. '81-'85.
I've got numbers from the EPC, rang Toyota, Nil stock..![]()
Just FYI
Nathans was the most povospec I've seen.
No aircon, shitty celica seats, guard mounted mirrors, 1G-EU, no LSD, T-series diff, vinyl sunvisors, vinyl ceiling?, L-type.
I'm sure there was more.
But it still had power steering
xA61's chassis, is longer from firewall to rack.. so no go..Originally Posted by xcedricx
mounting points on the crossmember are different..
track is wider on the xA61's than the RA60/5's..
My build plate
Model: E-GA61-BLPSE
Engine: 1G-EU
Frame No: GA61-0015xxx
Color / Trim
038 FS81
Trans/Axel: A42DL T282
Plant: A53
Donor car Crushed:
Model: E-GA61-BLMSE
Engine: 1G-EU
Frame No: GA61-0013258
Color / Trim
033 FS81
Trans/Axel: W57 T312
Plant: A53
both power steer.. But the GA i crushed had cruzz control & 5 speed.. yet the one i'm building had no cruzz..
Speak to Ed, he did it to my 84 model MA61. Its heavy at low speed but once it increases the steering is very direct & light enough. If you lose it big time though just let go or you'll pop your shoulder out![]()
If in doubt power out
I ran my MA61 for over a year with the P/S pump disconnected and the lines looped. It was heavy going but still driveable, although back then I had stock suspension and tyres. With my current setup I can barely move the wheel at all when the engine isn't running.
Norbie!
www.norbie.net
