thanks for that... i'll look out for it again on the manual .. at first the hand-controller doesn't look to friendly, so we'll seeOriginally Posted by chris davey
thanks again for the info..
30 - powerOriginally Posted by YLD-16L
85 - +ve from battery
86- earthed
so... 85 is from battery, 86 goes to earth... where does 30 go? do i wire up both the wires that go to the coil, to the relay, then just plug in 87 and 87A on the coil? sound right?
ill have to argue on that one, 87 and 87a are only on changeover relays.Originally Posted by YLD-16L
with a changeover relay when its not switched on, the power coming in pin30 will be leading directly out of pin 87a and only once you switch the relay on will you have power to 87 but it WILL take power away from 87a at the same time.
if you use a 5 pin make sure its not a changeover (as indicated by 87 +87a on the bottom of it) and then you can use both the 87's to run your coils.
linden
Originally Posted by WHITCHY
Here's a pic.
The bottom relay is the one you should look for. The top is a changeover relay.
Good point Linden, thanks for picking that up.Originally Posted by The Real Roadrunner
Interestingly though the el-cheapo Narva 30amp relay I used on the weekend was a 5 pin and layed out as '87' and '87a' and wasn't a changeover type, it's diagram was the same as the bottom relay in the pic above but with the 'a' after 87.
Just something to be aware of I guess.
+ rep (not for you YLD-16L, must spread love first)
so.. 30 on the relay is where i plug the original wires from the coil into? then 87 and 87A will be going back to the coil?
30 pin is the 12V+ from the battery.
.....and as mentioned and pictured if you buy a quality relay for the purpose you need it will have two 87 pins (non-changeover type) that will both provide the 12V+ that is connected to pin 30 when the relay is energised.
30 - 12v From BatteryOriginally Posted by Vios-GT_07
87+87 - Power out to Coils
85 - Ground
86 - Original power to coil
Or something around the lines of that.
MX83 Grande
DirtyWan Skyline GX
