I have already thought about this allot! and im going to agree with you kind sir...Originally Posted by The Witzl
after all you were the GENIUS that showed me how to rewire a 7gmte ignitor to work with a stock 4agze loom and ecu.
Yes the LED light testings will indicated the pulses comming out of the ecu and the X4box. - i assumed that you would just clip one of the test light on positive power and the probe of the tester on the tested object (in this case the looms in and out of the xbox) because the ecu is based on -ve circuit switching.
The ecu is mounted inside the car.. not in the engine bay.
yes i have given the channels double their intended load. - so i think its back to a new xbox ( picked one up about an hour ago) and stock ze coils for now.. that would be the best bet ey!
-Driftin DA' 86 Since way back -
BTDC and everything else is fine..
