Results 1 to 10 of 10
Thread: RA23 GT gauges,
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    Default RA23 GT gauges,
    hii,
    finally got around, to installing the GT gauges into my celica,
    i asked davGT4 who has done this conversion and he said he doesnt recall modifiying any wiring,
    so i simply pluged it in,
    end result,
    oil working
    amp not working
    temp not working
    fuel not working
    has any one done this conversion???
    can some one supply me with a RA/TA23 GT wiring diagram and a standered TA23 wiring diragram
    thanks
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
    Junior Member Grease Monkey Night Rider-TA23's Avatar
    Default Re: RA23 GT gauges,
    I had a standard ta23 one but i cant seem to find it, sorry dude.
    Jarrod
    Wednesday night BUMP
    RIVER WHERE THE BLOODY HELL ARE YOU???
    a good start would be to get both the clusters, and trace the wires on the back.
    i know for mouldyrollas, you need to swap 1 pin between normal and tacho dash, and add pin for tach input..
    i only have pics of one of the clusters.. but if you could take pics of both.... then we can trace em out and get 3/4 the way there if not further
    got a multimeter?
    I remember reading something about the 22's needing a different sender as the GT one was different and would not give an accurate reading.
    Just to clarify youve changed the amp, oil, temp, and fuel guages, not just changed to an oil pressure gauge and now the other ones arent working. Is this right?
    south austraila
    hhmmm
    When i changed the gauges on my RA40 it was plug & play..
    This was with a volt meter not the amp... As the amp meter needs to be rewired..
    The RA40 had 3 types of meters.. (1) oil & charge light.. (2) oil pressure & volt meter.. (3) oil pressure & amp gauge..
    set 1 & 2 will plug & play.. but 3 will need the amp rewiring...
    Oil pressure gauge needs a pressure sender..
    If you had a charge light it is best to replace with a volt meter...
    as for the fuel & temp they should be plug & play.. but check wires..
    Project: '82, GA61 XX
    70s Tragic Grease Monkey RA28tragic's Avatar
    Aug 2006
    I know a bloke who put GT4cv gauges in his 23. It is wild to see a speedo that goes upto 300k and a tach that goes to a bizzillion in a 23.. Mind you this 23 goes sidewides up the Samford range.
    Living in the 70s
    Ballarat Vic
    Did you put the GT circuit panel on the back of the gauges or did you leave the orginal one on? The wiring should be the same and you have to hook up the battery for volts.
    Get after market guages, they work faster and the old GT gauges just look good.
    Roscos
    well hopefully Owen can tell me more about the gauges,
    LeeRoy your right ive changed all four,
    OC i do have a multi meter, but dont know how to use it , will take pics on the weekend
    RA23/28 Gauges... You will need a fuel sender specific for the GT to get the fuel gauge going. The temp guage should work. The Charge light needs a pin moved around one. and there is a pin missing for the Amp. You should be able to work out what is what from these photos and possibly pulling the guage apart to compare.
    Top to Bottom both pics
    GT
    LT
    LT/GT (ie the one you have IBZ)
    Simon
    Beige.... The new Black!!!
  1. air con in to the ra23
    By kristian in forum Tech and Conversions
    Last Post: 25-10-2007, 05:56 PM
  2. 2T into RA23 (temporary while I rebuild 18rgu
    By floppy in forum Tech and Conversions
    Last Post: 29-01-2007, 12:37 AM
