Results 1 to 9 of 9
Thread: 1g boost controller pics
    May 2007
    victoria
    Default 1g boost controller pics
    Any one got any pics handy of there bleed valves on there 1ggte. Did a search couldnt find much
    livin on the edge as a Grease Monkey Snyper's Avatar
    south australia
    Default Re: 1g boost controller pics
    no pics close up, but you basically need to put a t piece in the hose for both turbos, one in each hose, then run a hose from this t piece into another t piece, with your bleed valve on the end of this one.. if you understand that easy enough..
    Brendon
    Daily - Prado 90series
    Work - T908 620hp Cummins ISX
    Shed - 1975 TA22 2TG
    Where abouts does each hose run form the turbos (i.e. location of it)? Also, where do you run it to?
    I've got a basic turbosmart boost controller that i haven't had time to hook up yet. All it says is one end goes to the turbo the other to the wastegate... As my car is my daily runner, I don't have the time to unbolt everything to find where it has to go... more detail would be appreciated and rewarded with I love you so much!'s
    Junior Member Grease Monkey GZ20 - Jake's Avatar
    Oct 2007
    id like to know where to put mine too lol theres a vacuum line from turbo to wastegate? seems pretty unreachable tho... id reward with a few love ya's too hahaha
    User Conversion King
    NWA
    you only need one pressure signal line so you just block the other one off.
    i bought T piece to suit the outlet from pirtek for like $5
    3 lines, one block off nipple and your done
    hello
    May 2007
    victoria
    Yeah i figured you took both actuator and comp housing lines and brought them to a t piece, just sounded messy
    Oct 2007
    pictures anyone? would be more than appreciated!
    Toyota fanatic Grease Monkey Gttwinturbomk3's Avatar
    Jun 2007
    Dunedin
    Picture didnt show up
    Jun 2007
    Dunedin
    Here is a pic of one typical way that you can connect a boost tap onto 1ggte.
  1. Best boost controller?
    Last Post: 31-01-2007, 10:24 AM
  2. Trying to wire up solenoid valve to boost controller?
    By trd-st162 in forum Tech and Conversions
    Last Post: 21-11-2006, 08:35 PM
  3. GFB Boost Controller > MA70
    By EldarO in forum Tech and Conversions
    Last Post: 16-04-2006, 04:39 PM
