Results 1 to 6 of 6
Thread: brake/wheel groaning noise...
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    Default brake/wheel groaning noise...
    hello
    i have recently put new rotors and pads in the ma61. they are bolt on rotors- ie they bolt to the rear of the hub.
    but, after heating up (either spririted braking or long drive on hot day) the front wheels begin to squeak, that speeds up and slows with wheel speed.
    when i slow down a lot (ie udner 20kmh) the squeak turns from a groan.
    does anyone have any ideas? there seems to be no clearance issues...
    only thing i can think of is if wheel bearing grease is reacting? (used two brands - dunno if thats safe, told it was) (yes it is high temp wheel bearning grease too)
    for anyone that doesn't know:
    ma61
    ra60 front struts
    ms65 hubs
    STi 326mm rotors
    z32 calipers
    thanks for any help
    Default Re: brake/wheel groaning noise...
    Are your calipers sticking on the slide pins when you get them hot? try removing the slides and cleaning the crap off them and re greasing them.
    Also you shouldnt mix two types of grease as they can react depending on the type is always best to clean and use fresh grease without overpacking bearings like most people do.
    71 ta22 2tgeu,ke35 18rg, ke 35 3k auto,74 ta22 2tg,73 ta22 2t,80 ra40 18rgeu,92 kawasaki gtr1000,95 nj pajero, 2011 jeep patriot,2011 aricat jd495,1979 leyland motorhome (350chev),1995 Mitsubishi Delica
    Too many cars so little time
    Montrose
    Z32 calipers are not sliding type. Have you got all the metal shims in place?
    G'Day mate,
    Did you set the bearing pre-load as per the TSRM? I'd be inclined to pull the hubs of and checking the bearings...
    Rudi
    pull it all down again, check for any wear marks/ tell tale marks, clean/wash bearings and re-pack....
    blake
    Quote Originally Posted by 7M-GTE MX73
    G'Day mate,
    Rudi
    shit!
    i suck balls at car things. will also check the shims and clean all grease and pop it back in.
    thanks guys
  1. Info: Emissions and Noise Testing
    By infotechplus in forum Tech and Conversions
    Last Post: 09-04-2007, 11:33 AM
  2. Replies: 47
    Last Post: 16-01-2006, 05:08 PM
  3. Brake 'groaning' noise
    By Andrew162 in forum Tech and Conversions
    Last Post: 05-12-2005, 04:09 PM
