Results 1 to 2 of 2
Thread: 4AGZE - MoTeC M48 install... questions
    Junior Member Backyard Mechanic Devils's Avatar
    Apr 2007
    W.A.
    Default 4AGZE - MoTeC M48 install... questions
    Hey guys,
    Well i finally got my AW11SC, loving it apart from a few niggly things which i will hopefully sort out soon enough!
    Anyway... Something that is high on the list, i've got a MoTeC M48 ECU sat here making a rather good paper weight on my make-shift computer desk. So i've thought of a couple of things that i'd need to sus out.
    The major one is the S/C Clutch. It seems to turn on and off when it feels like it, determined by RPM, Load and Throttle position. Am i correct here? Or is it more simple or more complex?
    Basically when i run it on the MoTeC, i'm thinking of maybe having a 'kill switch' for it as well, but what kind of output should i setup for it? Like Throttle position x load or just a simple switch controlled by a given throttle percentage?
    Ok and the next question is... are the idle control valve and the fast idle (air con one) simple 'air bypass' on/off solenoids with adjustable screws or are they a variable pull type (i.e. depending on voltage applied)?
    I'm sure there will be more questions but that's all that i've been thinking about today.
    Oh, where will i find a ECU wiring pinout for a factory AW11 '87 4AGZE?
    Devs.
    Default Re: 4AGZE - MoTeC M48 install... questions
    Getting the SC clutch setup is one of the trickiest parts of an aftermarket ECU setup on a ZE. Having it switch on load works OK, but you should have a timer so it doesn't switch off straight away. Somewhere on this forum there is a curcuit for a simple timer which does the job nicely.
    The aircon valve is a simple on/off valve, the idle is a 3 wire PWM valve.
    Try here for the wiring diagrams.
  1. 20V TPS & 4AGZE CAS -> MoTeC (check the working of Rex...)
    By Rex_Kelway in forum Tech and Conversions
    Last Post: 08-03-2007, 02:58 PM
  2. AE92 4AGE engine swap to 4AGZE!! Questions?
    By Ta22boy in forum Tech and Conversions
    Last Post: 10-10-2006, 06:00 PM
  3. 4agze solid engine mounts, oil cooler/relocator kit questions
    Last Post: 03-10-2006, 05:49 AM
  4. 4agze questions
    Last Post: 14-06-2006, 08:50 PM
  5. 4agze and sc12 questions
    By caibs in forum Tech and Conversions
    Last Post: 20-01-2006, 12:28 AM
