The engines are fairly different and i'm fairly sure that you'll need to use the standard engine mounts and bolt them to the ze. As for wiring it will be different to the ge and you will therefore need to use the ze wiring that along with the ze computer. You will also need to find the pin outs for the ecu so you can wire this up to your chassis loom so that you can have things working like gauges etc. I'm sure this has been covered eleventy billion times, do a search and ye shall find.
- LeeRoy
