Results 1 to 6 of 6
Thread: brake booster ra28
    Junior Member Backyard Mechanic bigmat's Avatar
    sa
    Default brake booster ra28
    guys i have to buy a new brake booster for ra28 and wondering if i should upgrade booster while im there.
    currrent setup im looking at
    r33 front calipers 4 spot
    gz20 rear single spot
    what i would like out of my breaking is good pedal feel eg solid and not to long a travel. i believe most new cars feel this way as my old bluebird is long and spongy with a new booster and master and it gives me the shits.
    i have searched but nothing screams out to me. thanks.
    Default Re: brake booster ra28
    Just use a standard booster, get a 1" master cylinder though. One of the supra MCs fit without much modification (bend a couple of brake lines a touch)
    Yeh stock booster is fine, brake feel is changed by having a bigger master cylinder. Some reckon the 1inch MC makes the feel too bitey, and 15/16inch is the way to go.
    Do a search, all the master cylinders have been talked about on here many times.
    For the nissan 4 spots, you will likely want a 1"... find out what was on the car they came off, and see if you can have a drive of one to feel whether it was stiff enough, or too stiff. There are also laws on how much travel you need to have, so check the NCOP.
    sa
    cheers. i think i will take my mates r33 for a spin and see if i like. just reading some stuff on dual diaphragm set ups. does this give better pedal feel?
    I think the 15/16 MC should be a better match for the Nissan 4 spots, unless you're running the Nissan 2 spots (or similar) at the rear...
    Joel (TurboRA28) is running the Mazda FC 4 Spots (which are almost identical to the Nissan ones) with a 1" MC, and he feels that it has too much bight and thinks he'd be better off with the 15/16 also...
    ([][][]II--LT--II[][][])
    By The Witzl in forum FAQ
  2. brake booster selection
    By STR8 2.8 in forum Tech and Conversions
    Last Post: 27-09-2006, 06:48 PM
  3. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
  4. Brake upgrades for FWD/AWD 5x100
    Last Post: 06-09-2005, 11:38 PM
