toyota has the valve cover gaskets... they were pretty cheap from memory![]()
Quick qestion doe the shims in a 1ggte match up to any other toyota engines ? makes GA70 supra is making a bit of noise when it comes to the buckets. also where can i get the top vavle cover gaskets ? might as well replace em while were there.
Ez
Hamgatan says:
i pwn my momma
Originally Posted by MR 1JZ
so what you just ask for 1ggte valve cover gaskets ?
Hamgatan says:
i pwn my momma
yeah a mate of mine got them from toyota he reckons... ill give him a call and find out...
They run the same buckets as 7m's and 4a's from what the EPC says.
$60 from memory....Originally Posted by fatboy13
'77 RA28LT #2 ← 2.2L 18RG...
If you get one with huge clearance (say 30 thou), pull the lifter and look at the area where the valve stem sits.
Sometimes the end of the valve stem leaves a deep impression in the bottom of the lifter bucket. Replacement of the bucket returns the clearance to spec.
If the bucket has failed, then sticking a shim in would be a band-aid repair...
Edit:
Given the description of the wear on the shim in the post below, nevermind. The problem is not likely the one I have described here.
its for my car actually. cheers ez for making the thread,
ive had a few replaced a couple years back but the noise has come back and i still have one of the old shims, by the looks of it before it has worn a slight dish into one of the sides and this was what was apparntly making them noisey as hell...
so should i bother asking toyota if they have them in stock?
1988 GA70 Twin Turbo (White)
1991 JZA70 (4STFED formally known as 4STAIR)
1987 GA70 Twin Turbo (Silver)
A decent size dealer should have shims in stock.
Depends if you need a new shim, or if you mind getting a used one.
I have seen two first gen 3sgte do that.
It will likely have worn the tip of the cam lobe. The two that I worked on, the customers opted to do the shim only.
The way the cam lobe was worn, I kind of expected it to come back, but they both made at least two years.
Do not wait too long though. I saw one head sitting in the corner of a machine shop, the damage to the shim had progressed to the point where it spit the shim out.
If you don't mind posting a picture of the old shim, I would appreciate it. I am kicking myself for not taking pictures.
Half of the ones in my 1G were like that, I replaced the lot, bought them from MD Spares.
did it quiet it down a bit and are they a pain in the arse to change? like how long would it take?Originally Posted by mrshin
depends how many times you have done it before.
ive done mine about 7 times (long story) and im getting pretty good at it. still a pita job though. to do a full set your best off removing the cams, which means having to retime the motor etc etc when your done. if you dont, after doing a few the hard way you will be kicking yourself, plus you cant check the underside of the bucket leaving the cams in place. id budget a good days work for a first timer, if many need changing. but before you order shims you have the measure clearance, measure shim, work out shim you need, swap what shims you can around, then order what you need. dont mix the buckets up, if you do you will have to remeasure all your clearances. be careful when tightening them cam caps too, do them with an accurate torque wrench, they have this ability to strip threads at really irritating times....
so why do they wear like that? they are meant to rotate in the bucket....
and spitting shims is no biggie, ive done it before lol
Originally Posted by love ke70
last time i heard your 'rolla (queen mary falls cruise) it sounded like all the shims were split... sure do hope it's better then that now...
on another side note... what's the most likely cause of noise from the top end if an engine has been left sitting for ages... i remembre hearing a noise the last time i started my 1G (over a year ago) sounded not unlike timing chain noise...
