Page 2 of 7 FirstFirst 1234 ... LastLast
Results 16 to 30 of 93
Thread: Microleb wiring assistance on 1JZ!!!11oneone!!11(LTX-12)
    Default Re: Microleb wiring assistance on 1JZ!!!11oneone!!11(LTX-12)
    two cam sensors on the 1Jizzle mate...one at the front and one at the back (yeah I thought it was odd when we removed the head as well), im assuming that its the front one seeing the wiring diagram from microtech says FRONT
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    Junior Member Grease Monkey Screaminrolla's Avatar
    I have a diagram here for the LTX-12 that says use the centre one only, it has the front crossed out
    1977 RA28 Celica 1JZGTEClick Me
    1980 Chrysler Sigma
    Then get to it! That would explain why you had no spark though.
    Who da F%^k is Takumi?? Backyard Mechanic 45aken's Avatar
    and whats all this LEB stuff about???
    AE86 - coming soon to a quiet mountain pass near you...
    WRX - currently epa'd...
    Quote Originally Posted by Screaminrolla
    are you 100% on this?
    Quote Originally Posted by JustCallMeFrank
    belive me when I say I cant wait too get home and keep working on it!
    Quote Originally Posted by 45aken
    its an SA joke I think? down here we call them the microleb electronic carby...basic, cheap, does the job and every leb and his cuzzin can tune it
    Thats what is written in front of me. I cant say if it works cause i dont have a 1J, it came with all the diagrams for my 1G
    1980 Chrysler Sigma
    It's not just an SA thing. It's just to do with the stereotypical sort of customers they attract due to their price
    well the plugs are the same, so ill wire one of the plugs in and try both sensors...hopefully this cures my no spark issue
    thanks mate...
    now
    +2 rep for all!
    I can't be assed digesting all of that, so I'll type anyway.
    To get spark you will need both the crank angle sensor and one of the cam angle sensors.
    You will also need the ignitor wired up correctly.
    After that, you should have spark.
    None of the other sensors are needed to get it running, but it will run like ass without them.
    o2 is for viewing purposes only.
    Plug the lappie in, turn it on, and crank the motor, you should see about 400rpm cranking speed. If you don't check to make sure you have both a crank angle sensor, and cam angle sensor.
    yeah there is a lot there...ive been typing like a receptionist on speed :embarrased:
    ive got all of the sensors already hooked up...the water temp sensor is off a VN commodore (god i feel dirty ) the air temp sensor is stock 1J, i am hoping it will read the correct impedance? Shane is that what you are running?
    No laptop either as the dongle and software are made of unobtanium at this stage, but ive managed to find someone kind enough to lend me thier 2 line hand controller which should suffice for a little bit for now...
    ive since figured out this morning via the help of some kind fellows that I dont have the cam sensor hooked up, as soon as I finish work im off to do that and fix up the ignitor wiring as coilpack 4 and 6 need to be swapped around, then it should be all good to fire her up and muck with the current tune a little...
    Cruz do you know if the 2JZGTE 440's are a direct drop in on the 1J? I have already established they fit and the plugs are the same becuase that is done...but is there an issue with impedance or are they all good in that respect?
    Microtech can run up to 2 2ohm injectors per channel.
    So one 2ohm injector per channel (presuming they are low impedance) is no issue.
    440s are high impedance like the 370-80's
    ALso, don't forget to compensate for the larger injectors in the fuel map. I am pissed that you can buy this thing and have it wired in like 2 days and I still don't have my car doing ignition
    QUICKEST 1JZ'S IN OZ
    thanks for confirming that chris...
    thats ok then, that means they will pulse correctly as this leb came off a 1J already, they will just give too much fuel...
    we are gonna lean off the tune a little as it was already a very rich (read: safe) tune and with the 440's it will be even "safer", probably so safe it wont idle, I wont be driving it much on this tune as im getting sick of 7 psi...I rang the tuner this arvo and he reckons if the cold start is ok then he can have it tuned in half a day for me and have it making around 300rwkw
    it will happen for you too mate...dont worry about that
    Mr 1J: I'm pretty sure it's the front cam - I'll check for you when I get home (4pm). also note that I had 2 ltx-12 1jz wiring diagrams, and they BOTH had the cas/cam sensor wiring wrong. I can't remember what the correct wiring is, but I just ended up using trial and error till it started co-operating with me
    if you get stuck I'll check the wiring colours for you (but I'd really prefer not to, being under heat shrink and all)
  1. Replies: 0
    Last Post: 07-02-2006, 12:01 PM
  2. 7MGE and MS55 wiring diagrams
    By fatboy13 in forum Tech and Conversions
    Last Post: 29-12-2005, 02:37 PM
  3. AE111 Wiring Diagram
    By Steve-AE86 in forum Tech and Conversions
    Last Post: 28-12-2005, 09:57 PM
  4. gearbox wiring
    Last Post: 20-12-2005, 11:34 AM
