Results 16 to 23 of 23
Thread: Are side pipes on T18 legal??
    Default Re: Are side pipes on T18 legal??
    But is same distance from wheel arch to door as a ra28. So why can it be engineered on a 28 but not a 23 if the 23 rear windows are no longer functioning?
    Jase
    JZA023
    'Cause they're legal ....
    www.billzilla.org
    Toymods founding member #3
    So i could have it on a 23? Im a lil lost with that last one bill lol
    Jase
    JZA023
    Quote Originally Posted by w810sc
    cut and paste from:
    http://rvcs-prodweb.dot.gov.au/files/4204.pdf
    and more at:
    http://www.dotars.gov.au/roads/safet...s_3Feb2006.pdf
    i've been reading up on this topic for a while as i too am going for a side pipe'd 2T-G.
    fonz
    So does that mean we can do it fonz?
    Im so going side pipe on the 2 if so!
    -Just Alloy Radiators-
    www.alloyradiators.com.au
    But Nath, from what ive gathered you'll need to remove your rear window mechs to make them 'fixed'...
    Jase
    JZA023
    I don't think that removing the winding mechs classes them as fixed...
    They need to be permanantly sealed, and you could still force the window down if you remove the mechs...
    Possibly, if you were to weld the mechs solid, then it may class as permanantly sealed, but that would then be at the discretion of the engineer...
    ([][][]II--LT--II[][][])
    hrmmm... This is true...
    Doesnt blake aka INOCNT have side pipes? Where is he right now?! lol
    Would the engineer remove trim to ensure they are fixed rear windows? Or if you were to say they were fixed via welds, or fixed from factory, would that be enough to feed his curiousity?
    Jase
    JZA023
    Fixed from factory or proven by engineer to be fixed (and sealed)
    Simon
    Beige.... The new Black!!!
    Last Post: 12-07-2019, 05:11 PM
  2. Steering help, freeplay on drivers side wheel
    By Da_Ronz in forum Tech and Conversions
    Last Post: 09-01-2007, 09:39 PM
  3. Bending downward 4cm of 1 side of a xA6x Chassis HELP ME !!!! :(
    Last Post: 03-01-2006, 05:56 PM
