Results 1 to 6 of 6
Thread: choosing jets for weber on 4K
    Default choosing jets for weber on 4K
    ive been asking this in the KE corolla thread and thought id put it out there
    i have a 4K (3k head, 4k bottom) with stock cam and a 32/36 DGV weber to play with
    there is not much suggestion on what jets to run on the net and was looking for some advice from anyone who's set up a weber on a toyota engine
    ive taken out all the jets at the moment it has
    primary main jet = 127, aircorrector = 115, emulsion tube = F66, idle jet = 55
    secondary main = 125, aircorrector = 160, emulsion tube = ???, idle jet = 60
    (??? means there was no markings on it)
    now i think the air correctors are in backwards, am i correct?
    from research everything else is fine but i was gonna get a 150, 140, 135 and work my way down with the primary and 125 seems fine for secondary.
    any suggestions on what would be the best jet sizes to use?
    thanks
    Default Re: choosing jets for weber on 4K
    you have 26/27 chokes, so you might need bigger main
    i had 150/150 in 24/27 34DMS... but i thin kthe idle circuit was not so could, so if yours is woring a smaller main would be ok...
    bigger for sec... corrector is secondary... get the idle, then the main,, then.. there are guides out there
    south austraila
    i have 2 x weber book's ....
    You say it's a 4K... Q:- what it's cc.. ?? 1600, 1800, 2L..?
    i will look it up & posr jets best suited..
    Project: '82, GA61 XX
    ga61 they are a 1.3 (1290 cc)
    south austraila
    these jets on a 1300
    primary main jet = 125, aircorrector = 180, emulsion tube = F50, idle jet = 55
    secondary main = 130, aircorrector = 195, emulsion tube = F66, idle jet = 50
    these jets on a 1600...
    primary main jet = 140, aircorrector = 165, emulsion tube = F50, idle jet = 55
    secondary main = 135, aircorrector = 160, emulsion tube = F6, idle jet = 50
    try these...
    thanks guys +rep
    EDIT: You must spread some Reputation around before giving it to hosking1991 again.
    ill get u next time bro
  1. Correct 2R carburetor Jets??
    By jfallen in forum Tech and Conversions
    Last Post: 07-07-2007, 06:54 PM
  2. what jets to use in 3k carb on 4k bottom end
    By rob in forum Tech and Conversions
    Last Post: 17-06-2007, 10:30 AM
