Results 1 to 11 of 11
Thread: Where do i get an Oil Temp Gauge Adaptor Plate?
    Junior Member Grease Monkey slydin-cressy-style's Avatar
    Default Where do i get an Oil Temp Gauge Adaptor Plate?
    Hi guys
    Im after an Oil Temp Gauge Adaptor Plate to screw my oil temp gauge probe into
    Does anyone know where to get one for my Cressida (which has a 1J) ?
    SUPPORTING AUSTRALIAN PERFORMANCE PRODUCTS...
    TURBOSMART MICROTECH JUST ALLOY RADIATORS
    THANKS TO:
    - ALL TRANSMISSIONS - IMPORT AUTO PARTS
    - P.I.T.S - PLATNIUM AUTO CARE
    Default Re: Where do i get an Oil Temp Gauge Adaptor Plate?
    could try speco
    speco.com.au
    or weld a bung into the sump
    There's stacks of them on eBay, that's where I got mine. Toyota uses the same filter size as Ford which makes it easy.
    victoria
    speco does one with two 1/8 bsp ports on it
    is firing on all eight. Carport Converter AndyTTR's Avatar
    You can get one ordered in though Superheap or Autobarn. They're about $60 iirc.
    As mentioned previously, I used a generic Ford Z9 adapter plate on the Celica and the Soarer.
    JZA70|R / 12.45 @ 111 mph.
    Not just a regular Backyard Mechanic ProjectSleeper's Avatar
    I think I still have my original one her somewhere that I didn't use..
    ( I went with a full relocation kit)
    Hachi Rusto Backyard Mechanic Julz01's Avatar
    get a speco one, you can buy them from auto1/rarespares and only cost about $30 , alot cheaper then ebay/online performance sites
    Another option is to drill and tap the oil filter union bolt to accept the temperature probe. From memory there's a howto guide on mkiv.com.
    Does anyone know what thread i need if its for a 1j?
    Josh
    THANKS TO:
    Drilling and tapping into the sump plug wouldn't be a bad option either if your engine used one of those chunky sump plugs... hmm... i think i'll have a look at mine next time it's out.
    Edit: I think the thread for the oil filter is 3/4"-16UNF... don't quote me on that though.
  1. 18RGEU after market Temp gauge
    By normo in forum Tech and Conversions
    Last Post: 14-10-2006, 07:34 AM
  2. Temp Gauge Problems
    By Ghostrider in forum Tech and Conversions
    Last Post: 12-09-2006, 06:55 AM
  3. Blitz Exhaust Temp gauge wiring
    By 1200det in forum Tech and Conversions
    Last Post: 08-06-2006, 04:56 PM
  4. Water temp gauge install
    Last Post: 21-02-2006, 10:45 PM
  5. RA/TA2x oil temp gauge sender..
    By celica-fiend in forum Tech and Conversions
    Last Post: 30-01-2006, 12:57 AM
