I can get the toyota part numbers when I get home for you if noone has helped you before then.
What gearbox are you using?
Hi all,
I searched high and low, but I still have no idea where to look for.![]()
What I am after is information on BOLTS for 1JZ Bellhousing to the engine, and BOLTS for the pressure plate?
Anyone know anything about them? part number from Toyota?
I was told to get the old one and measure it, then take it to the Bolts places, but I have no old ones. Start from scratch for my conversion.![]()
thanks,
I am the sun
Hi Dale, Yes please. Thank you.
I am using R154.
90119-08302 is the part number for pressure plate to flywheel bolts, that's the number for a single bolt
I'll get the part number for the the bellhousing bolts when I get home tonight
I am the sun
91611-61040 is the bell housing bolt number... not sure how many you need, 4?
I am the sun
sweet az,
thanks Dale, I think atleast 8 bolts.
cheers,
Hmm that's probably just the main setting bolts then (as in the big bastards)... there's probably 2 more for the starter, and maybe 2 more holding cover plates/brackets or something?
I am the sun
