well without measuring it i can't tell you an actuall figure.
but it can be as close as 20mm to the lowest most part of the motor (without the sump on) , between that and the xmember IE: you need 10mm between the lowest part of the engine and the sump (which can be as thin as 2mm alloy) then a further 8 mm to the xmember.
linden
edited
			 How much lower can an engine go from dry sumping?
