Results 1 to 13 of 13
Thread: sump baffling
    Default sump baffling
    rather than just welding plates in a sump any old way, does anyone have pics or know the best placement and angles for putting baffles in a sump, which work the best?
    cheers steve,
    1ggte, 11.22 @122mph
    Penrith BC
    Default Re: sump baffling
    depen
    ds entirely what you want to baffle it for
    ../delete/ban
    tech moderator
    are you still running the factory baffle plate?
    ed, under hard braking and left hand corners oil pressure seems too drop away, hard right hand corners doesnt move at all, oil pick up is 5mm off the bottom of the sump, so all is good there, and yes there is enough oil in it, the sump has been modified, which is probably not a good thing by the previouse owner it looks as if the bowl has been moved forward too clear the crossmember rather than hitting with a hammer to make it fit, you pretty much cant tell its been modified till you look inside it.
    blake, there are no baffles in the sump at all, if you talking about the plate that bolts between the sump and the block then yes the standard one is still there.
    cheers steve,
    Penrith BC
    front and right trap door baffles around the pickup?
    ../delete/ban
    tech moderator
    has the pick up been modified also? possible that its not air tight,...?
    Linden baffled mine for the supra 7M. In essence it's a chamber around the pickup with a flap on a hinge that lets oil in but not out (plus about an extra litre of oil capacity)
    Forum Sponsor Conversion King
    Dec 2006
    that was just so i can charge you more for oil it will double as a coolant overflow also, ahhh 7m pooness
    linden
    Well, I wasnt going to mention that it had to be re-made after it fouled on the pickup, but.....
    quoted for truthfulness
    Quote Originally Posted by Draven
    Dont you talk 2J boy, how long has your car been on the road for? Didnt it eat a turbo after 0 kms driven?
    Dec 2006
    hey hey, what fouling? or are you talking about that pisspoor bracket that somebody had put on there b4 me. i just cut it off and the so called fouling was gone (C&B are lazy kents)...speaking of which *adds modified sump bracket to invoice*
    linden
    linden
    i think you take the cake for the 7M COMEDIAN
  1. Cressida MX73 Conversions Guide Book
    By twentyEight in forum Engine & Driveline Conversions
    Last Post: 24-02-2007, 10:07 AM
  2. 1g-gte front winged sump into TA23 Sway Bar issues!
    By hemi twofifteen turbo in forum Tech and Conversions
    Last Post: 22-09-2006, 09:27 AM
  3. Sump position model guide (SPG#)
    Last Post: 31-01-2006, 01:15 PM
