Results 16 to 30 of 41
Thread: Engine choice??
    Junior Member Backyard Mechanic jezza323's Avatar
    Default Re: Engine choice??
    id definately be going with the 3tc + turbo given you already have some of the parts, then once the suspension/brakes/driver are sorted, and if i still wanted more power, id look at changing it then
    Montrose
    Why not stick in a 4G63 and have the fun of upsetting everyone?
    GT4 Freak, and Conversion King Squid's Avatar
    I reccomend 3s great engine...
    (I also have one for sale )
    Seriously, it is a great option, but a fair bit more work than some of the others... I guess it depends how much you are willing to put into it!
    ST185 GrpA #116
    ST165 GT4 Project Car - Soon with v6 goodness.
    The glass is neither half empty nor half full, rather the glass is twice as big as it needs to be.
    Junior Member Grease Monkey Night Rider-TA23's Avatar
    A 3TGTE is the easyest most logical choice for a ta23 as it will pretty much bolt in, but the mods suggested earlier would need to be done to gain the power output you are after, and as for the 1g, hands off the one for sale that was suggested, with any luck it will be mine soon
    Anyway good luck with what ever conversion you choose
    Jarrod
    Quote Originally Posted by Ical
    If $$$ avail maybe a Dutton/Hill climb will be tried.(its a toy after all).
    If you're concerned about having the money to enter Dutton or a Hill Climb event, then the 3S-GTE route is a massive no go zone for you...
    Being a TA23, then I'd go for either a 3T-GTE (but parts are getting harder to find), or my personal choice for such a vehicle, a 4A-GTE (using a 4A-GZE as a base)...
    If you were going to use your RA23, then a 1G-GTE or 1G-GZE would be the route to head down...
    Obviously, you could just swap the crossmembers over, but you may as well stick with the TA23 and go the 4A-GTE path, especially because the 4A-GZE has forged pistons from factory...
    ([][][]II--LT--II[][][])
    T'ville, QLD
    is a ta23 x-member not desireable for 1g conversions?
    2T out 4A in....
    I believe the RA23 is much more desirable as the 1G will bolt straight up to it with 1G-GE mounts...
    (Maybe it does also with the TA23, but I have a feeling not...)
    oregon
    After a few years away from rallying(family house's etc) I've bought back
    My old Ta23 celica.I have enough spares for a few cars and a spare Ra23 rolling shell.
    The question is,With which engine will i re- power the old girl with.Options are,(would like over 200rwkw).
    1. Inject & turbo a 2t/3t eng.(got 2 of each & numerous g'boxes)
    2.4age turbo'd.
    3.3sgte.
    4.1Jz.
    The car is 3rd car and will only be used weekends etc.If $$$ avail maybe a Dutton/Hill climb will be tried.(its a toy after all).
    Any advice from people who have been there would be great.
    Cheers Ian.
    Why not a supercharged 3RZ-FE??? May be lame suggestion since I don't know availability... but the 2.7 big 4 with a supercharger will supply enough torque for any xA23 and it may even break 200 rwhp while doing it
    3RZ is a cool idea if chasing big power, but they are pretty heavy and also very tall so bonnet clearance may be a problem.
    Aug 2007
    MMMMM Choices Choices,
    I will be using the RA23 as by the DOT fun police i can go upto 2.6+Turbo.
    The old rally car(ta23) is looking to be more work than the other(ra23).Prob due to
    a hard life and been sitting for 7yrs(1/2 outside).But i have most the good bits back
    and enough spare's to build 2to3 cars Shells pending.
    As regard to 3sgte,in a ball park figure when people say costly/expensive how
    much are they talking about? What you might call costly i maynot.(Used to pay
    for Raliying).
    Cheers Ian.
    RWD 3S-GTE conversion $8k+ (Depending on mods...)
    And that's being conservative...
    Aug 2007
    Quote Originally Posted by twentyEight
    And that's probably still being a little conservative...
    Ok' will ad to plan,still not to bad by the time i build a inj&turbo 2/3t eng.
    Thinking,
    1/2 cut engine $ 2200.00
    W58 box $500/$1000.00(not sure)+
    Bell housing $$?
    Can fit myself.
    Mate can rewire.
    Alls left is plumbing & fiddly bits.Probly most costly?
    Sorry for long winded Questions but i think i would like to do it once, not 2t to 3sgte.
    Cheers Ian
    T'ville, QLD
    Thinking,
    Bell housing $$?
    Can fit myself.
    Mate can rewire.
    Cheers Ian
    add that up then double it
    2T out 4A in....
    W58 box $600
    Bell housing, Throwout fork, and bearing - $250
    Can fit myself.
    Mate can rewire.
    Custom RWD Inlet Manifold - $1000
    Custom RWD Turbo Manifold - $600
    Custom Flywheel - $700
    Clutch to suit Custom Flywheel - $800
    Custom Water Housing - $150
    Custom Alternator Bracket - $120
    Custom Engine Brackets - $150
    Modified 2S Sump - $200
    Custom Dizzy or CAS setup - $400
    Aftermarket ECU - $1200
    Exhaust and Dump pipe to suit Turbo - $1200
    Intercooler and Piping - $600
    Fuel pumps, surge tank setup, and new fuel lines - $650
    Plus loads more...
    That's already $10820!
    dont forget a clutch to suit the custom flywheel/W58
  1. Toyota R Engine History
    Last Post: 02-12-2011, 08:41 PM
  2. MA70 --> JZA70 Conversion
  3. engine ideas
    By Blade20034 in forum Tech and Conversions
    Last Post: 17-10-2006, 07:23 AM
