Page 3 of 3 FirstFirst 123
Results 31 to 41 of 41
Thread: Engine choice??
    Default Re: Engine choice??
    Quote Originally Posted by jezza323
    dont forget a clutch to suit the custom flywheel/W58
    Added... Cheers!
    ([][][]II--LT--II[][][])
    Forum Sponsor Conversion King
    Quote Originally Posted by twentyEight
    Custom RWD Inlet Manifold - $1000
    Custom RWD Turbo Manifold - $600
    Custom Flywheel - $700 not needed for a 4s bell as the standard 240mm will fit.
    Clutch to suit Custom Flywheel - $800 same as above
    Custom Water Housing - $150
    Custom Alternator Bracket - $120
    Custom Engine Brackets - $150 he can do himself (apparently)
    Modified 2S Sump - $200 same as above.
    Custom Dizzy or CAS setup - $400 std dizzy with a cap (not needed but nice to have) or a big hole in the firewall (with some sort of plate to cover it) and run the std dizzy and ignitor setup.
    Aftermarket ECU - $1200 not needed as you can use the factory ecu but need some fancy electronics for waste spark if stock dizzy isnt used
    Exhaust and Dump pipe to suit Turbo - $1200
    Intercooler and Piping - $600
    Fuel pumps, surge tank setup, and new fuel lines - $650
    Plus loads more... depending on how far you really want to go
    That's already $10820!
    please remember that things are only as hard as YOU make them and some conversions can be done for reasonable prices depending on how far YOU chose to go with it.
    if i was to do my setup for somebody else it would be $35k for a turnkey job but that was with everything apart from the actual shell being replaced/modified.
    linden
    Certainly true...
    There's massive savings to be had if you can do alot of the fabrication yourself or if you can purchase already fabricated/modified items...
    3S-GTE conversions don't seem very hard on paper, but everyone who's actually done it has ended up spending a lot of money. I'd love a 3S in my RA23 but in terms of bang for your buck the 1G poops all over it.
    but it wont be as good a track car with a 6cyl in there.
    its not hard you just have to be smart about it or very handy with fab equipment.
    linden
    also the gen engine you pick will have a large bearing on the end result if you do go a 3s.
    personally i would only use a gen3 or later. tell you what the best one for the conversion would be a st215 caldina coz they were multicoil factory so no ecu mods. but the integral exmani/turbine housing is a bitch.
    One point to consider if you're chasing handling/low weight etc is use the smallest engine that will make the power you're after, which would be a 4AGTE. Before I turbo'd mine it had a weight balance of 51/49 front rear, & there was a fair bit of room between my motor & firewall, so it would be possible to mount it further back. Plus there's not alot of custom work required to build & fit a 4A, alot of stuff is available off the shelf or from wreckers.
    The 3S is a great engine, but as has been said fiddly to fit, lot's of custom/hard to get bits required, although it will easily make what you're chasing & give a good compromise on size/weight vs. power potential.
    and the 3s wont be lacking in torque like a 4a (and yes ive owned both and in the same car)
    its the off boost moments that the difference is huge, and always remember the area under the curve.
    linden
  8. #38
    Aug 2007
    Hey Bigworm,
    How's the drivability of your 4a?Is she hi strung?
    Cheers Ian.
  9. #39
    linden
    Was the 4A equipped with a 3 speed & a T78?!?
    Ok, yes a 3S will have more power down low, which is always desirable, but with the smallest turbo that will efficiently make the required boost you're not going to be that far behind a 3S. Plus it's cheaper/easier/lighter.
    I'm not dissing the 3S, it's an awesome motor & all that, I'm just defending the 4A. For its size & ability (and age), it's an impressive thing.
  10. #40
    This thread has so far failed to point out that real men use 18R-G's. Ask River.
  11. #41
    Quote Originally Posted by Ical
    Hey Bigworm,
    Cheers Ian.
    It was very drivable (but is currently off the road & turboless).
    The turbo was an HKS GT2510, which I run up to as much as 25psi & 180rwkW on a stock rebuilt motor, standard cams/intake etc, just uprated valve springs & metal head gasket.
    On 12psi (approx. 120rwkW) it was very responsive & smooth, making full boost very early, with 25psi it obviously made full boost later in the revs and felt much peakier, but I wouldn't describe it as high strung.
    And with a few mods like cam gears, better intake manifold & better turbo manifold, even mild cams & slight port work it would make more power at the same boost & if setup correctly more power down low.
  1. Toyota R Engine History
  2. MA70 --> JZA70 Conversion
  3. engine ideas
    By Blade20034 in forum Tech and Conversions
    Last Post: 17-10-2006, 07:23 AM
