Page 16 of 18 FirstFirst ... 61415161718 LastLast
Results 226 to 240 of 256
Thread: 2.2 litre 1G Stroker kits
  1. #226
    Default Re: 2.2 litre 1G Stroker kits
    tighe have a grind that matches HKS ones, i know cause i had to have a set sent away and repaired.
    i now have 2 sets, so one day i might sell the 264s, keep the 272s, i think
  2. #227
    Aug 2009
    mind telling me how much they cost?
    Project:RA65 with an engineered 1ggte conversion.
    Daily:MA61 - 5me stock auto shitheap.
  3. #228
    one set came with my HKS stroker motor, and the other set i got very cheap of a malaysian bloke as they were no good for his car, and just swapped him some parts, which all fell apart when i lost contact with him, dont know what they are actually worth.
  4. #229
    I sold my spastic 304 duration cams for 1k on ebay just the other day. they were brand new.
    RA23 - Twincharged
    JZZ20 - Daily
  5. #230
    The cheaper rods would be made in china.
    The spool rods are made in USA.
    I know which id prefer
    RA23 - Twincharged
    JZZ20 - Daily
  6. #231
    Aug 2009
    Pass on china.
  7. #232
    Slanted Photographer Automotive Encyclopaedia LeaThaL's Avatar
    Aug 2006
    id be interested soon enough im some cams and a stroker if their a decent price, i want a mildly spastic ga70 i think
    1 G L O V E
    88 Ga70 supra --- Under powered and over cooled Daily
  8. #233
    Aug 2009
    I priced cams through Tighe cams the other day.
    $1250 for a new set, they don't have any on the shelf, but they can make a set up.
    If a few others were keen, could prob try get the price down a little.
  9. #234
    Junior Member Backyard Mechanic slipway's Avatar
    brisbane
    What's the story with the strokes piston,any around? Quite interested in a set of rods either way. Are they to suit gen 3 crank?
  10. #235
    Brad from spool has sets made for the klye stroker engine. they are 3mm longer than stock. You need a gen3 crank offset grinded to use them and custom undersized pistons (1mm).
    RA23 - Twincharged
    JZZ20 - Daily
  11. #236
    brisbane
    sorry should have been more clear but i mean did the pistons ever get made, is there spare's and are the normal spool rods to suit gen 3 or gen2 crank?
  12. #237
    no idea about the pistons sorry.
    the normal spool rods would be made for gen2
    RA23 - Twincharged
    JZZ20 - Daily
  13. #238
    as far as the disaster that was the original group buy goes, i do not believe any pistons ever got made, but i might be wrong...
  14. #239
    brisbane
    ok so possibly retarted question but if i remember correctly the pin was 1mm higher in the cp's so could 1mm be removed from the factory pistons without making them to weak.
    from pictures i believe there is fly cuts also witch would be hassel. and could you get away with some hks 272 with decent lift cams?
  15. #240
    pretty sure the offset grind gets the piston 1mm further up at TDC. Then the 3mm longer rod should send the piston 4mm further up. So the custom cp's would have a 4mm higher pin.
  1. The HKS 2.4 1G stroker....... Isn't 2.4 :o/
    By 6BOOST in forum Tech and Conversions
    Last Post: 06-01-2008, 11:24 PM
  2. KBox seal kits for various Toyota's
    By parrot in forum Tech and Conversions
    Last Post: 17-07-2007, 11:26 AM
