Page 96 of 139 FirstFirst ... 46869495969798106 ... LastLast
Results 1,426 to 1,440 of 2085
  1. #1426
    Interesting, the stuff i used for the bonnet is an Acrylic Enamel. Let me go take a photo of the can
    Edit:
    Went on like a normal thinned acrylic though.
  2. #1427
    Is that stuff UV stable and glossy Takai?
  3. #1428
    Its glossy. Not sure if its UV stable. I had to do the bonnet in it because the can of 2pak got knocked off the shelf in the garage before i had done the bonnet. I didnt particularly feel like pushing the bonnet around on the ground to get good coverage
  4. #1429
    Anyone have an opinion on that paint that i posted earlier? Keen to get a tin of something so i can at least start on the Supra over the holidays.
  5. #1430
    Stu,
    For a fine filler, look at the U-Pol Hot Shot. Working quite well for me, and sticks to panels like shit to a blanket.
  6. #1431
    Takai that DUPONT paint is probably an acrylic, but the "enamel" has been added as a marketing strategy to tell people it is glossy like enamel. Enamel always give a good gloss straight off the gun.
    cheers Chuck.
    MS51Crown Coupe,
  7. #1432
    Nah, its definately not a plain acrylic. I have a random sheet of steel i use to calibrate the gun and when i popped some acrylic over the top of the 3 day old enamel it bubbled up when dry, like there was still stuff drying off on the enamel.
    This gave a good gloss off the gun.
  8. #1433
    Eltham vic
    dupont enamel /acrylic and 2k are compatible with each other
    dupont tint up the pigment to make the color , then add the binder that determines weather its acrylic enamel or 2 pack
    also ,with todays iccyanate free products in 2pack you can even reduce it with a good quality gp thinners
    if you have a dupont stockist ask for the data sheets to read ,
    you will be surprised with how versatile it is
  9. #1434
    FastDry™ Machinery & Equipment Acrylic Enamel (435-96 BINDER)
    Designed for quick, easy and economical refinishing of machinery and equipment. this acrylic enamel product ensures better durability compared to other air dried QD enamels on the market.
    tech sheet
    http://www.google.com.au/url?sa=t&so...3nqQhtpuTo571g
    MSDS has the main solvents if that helps identify?
    http://www.dupontpc.com.au/assets/pd...435-96_RFN.pdf
  10. #1435
    This certainly isnt compatible with the K&H Acrylic i was using to do the insides of the doors etc.
    Looking at it today its come up quite glossy with only a few areas of orangepeel
  11. #1436
  12. #1437
    Hm, i havnt been able to find any definitive stuff on it. I reckon ill go ahead with it for the Supra though, it was good stuff on the Sprinter.
  13. #1438
    Went and had a chat to the paint shop today. Seems its the same base and colour as the 2K stuff, but merely with an air activated binder rather than a catalyst activated binder.
  14. #1439
    wandering around the local (now) DIY centre here near Yokohama... they have Anest Iwata guns!
    the W101-131GC (gravity 1.3mm) is about $190 with a 400ml metal pot...
    http://www.anest-iwata.com.au/range/detail/w101.shtml
    good deal? still a fairly basic gun? too small a tip for acrylic?
    hm, this setup. only a bit cheaper than ebay minus postage etc.. http://cgi.ebay.com/ebaymotors/ws/eB...5123&viewitem=
    tbh, it looks like it may be not much better than the workquip, although feels and looks better but not a big step up?
    they didn't have W200/400's there
  15. #1440
    W101, I would buy a gun like that. 1.3mm is right there for spraying acrylic, topcoat, and 2pak. I use a 1.2 or 1.4mm gun for all of the above.
    cheers Chuck.
    MS51Crown Coupe,
    Last Post: 06-01-2010, 09:34 PM
    Last Post: 23-09-2007, 12:52 AM
    Last Post: 11-01-2006, 10:53 AM
