Well SamQ, i must say i got great respect on your enthuasiasts on FE. Which is good.
Im not sure what is the duration of my 7AFE cam but i was told its 7.6 lift for both side. As for the speedzone cam, well i must say even i myself also give up on them. Whn they dun reply email or reply details thru phone calls, to me they dun deserve the business.
I do have a freind who had his cam reground at Crower hence i shoot crower an email. This is what he replied. Oh yeah, should you saw the spec or info i given to them was incorrect, do let me know.
----- Original Message -----
To: Frank Chong
Sent: Thursday, November 29, 2007 12:06 AM
Subject: Re: Custom ground, proprietary cams
Yes.
Re-grind only.
Non v- tec cams avrage $100 per cam re-grind.
Send them on down!~
Dj
To: [email protected]
Sent: Tuesday, November 27, 2007 11:19 PM
Subject: Custom ground, proprietary cams
Hi Crower
Im looking for custom ground cams for my JDM Toyota Corolla 7AFE turbocharged engine. I do know Crower had done a custom ground cam for the 4AFE Turbo engine before. My engine was totally in stock form except 1.2mm metal gasket. Im not sure what is my stock cam duration but i do know its 7.6 lift. I hope you can find these information helpfull.
Bore & Stroke
3.19 x 3.37
Compression
9.5:1 (before 1.2mm gasket)
the intake closed at 38° ABDC, exhaust opened at 42° and exhaust closed at 2° ATDC. Intake valve opening at 6° BTDC.
RPM Redline 6200rpm
Currently im looking at this cam spec. Will need your expertise advise should this cam works.
264/8.1 & 256/8.1
Do i need to send in my cam? Tks
