Results 16 to 30 of 37
Thread: Custom cams with no aftermarket support
    Aug 2006
    Default Re: Custom cams with no aftermarket support
    How much do you intend to spend on these cams?
    surely there would be an after market option somewhere
    Yes i think nitriding the cams would help if prone to chips, i cant explain it but they wouldn't do it for no reason would they.
    Bill, what does that Kelford guy charge for a weld and grind for someone like me?
    also do you think theres any merit in getting cams off that Sirazul guy? he doesnt seem to like answering mail at the moment. Would he just be selling welded cams himself or is he C&C lathe/milling them?
    do I have any other options?
    Sirazul get his cams in Aus AFAIK, but I can't remember from who. I think he sells both kinds of reprofiled cam.
    As Jezza mentioned Phil charges about $30 per lobe and $40 per stick.
    www.billzilla.org
    Toymods founding member #3
    Quote Originally Posted by blacktopspirit
    no, they would not help with chipping. please try to explain it next time
    nitriding is process where nitrogen goes into surface and solution strengthens the steel. if there is chromium etc there, it may form hard nitrides. it is only a very surface technique, it has little penetration (compared to say.. the usual induction hardening for cams).
    nitriding is only done to reduce wear.
    it is strange to do it on cranks.. unless you are expecting to run low oil pressure and want to save the crank from being reground when you spin a bearing
    if something chips, it is either because there are internal stresses from the formation process (ie, from the hardface welding), or because the material is too brottle (ie, stellite).
    the crack will propogate below the surface, deeper than nitriding will ever touch.
    basically, hardfaced cams are prone to chipping, because of the complex metallurgy that occurs during the repeated melting and solidfying.. and because the filler metal is also relatively brittle...
    that said, if the operator does a good job... they may nto chip at all
    but if they have issues (they may not even be able to tell at the time), then it will suck
    but if you have no choice.... you have no choice.
    perth
    v12 jag cranks are nitrited (spelling) standard
    cranks should never touch their bearings
    (nitrided)
    oregon
    (nitrided)
    except at rest
    well I just got a quote form Clive cams, $780 for the weld and grind, so unless I sent it to antoher state that might be what I am stuck with.
    whats your timeframe? when do you want them done by?
    just a quick one,
    4AFE buckets aret he same diameter as 4AGE, dunno about 7AFE ones though (i test fitted a 4AFE one into my spare smallport head)
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Quote Originally Posted by shinybluesteel
    just a quick one,
    4AFE come with either 28mm or 31mm buckets, depends on the type of head.
    AFAIK all 7AFE are 31mm.
    www.billzilla.org
    my time frame is from 6 months time to a 1+ years time, I have too many other things to do
    about the same as my timeframe if you like i can talk to Kelford Kams about your requirements at the same time as im doing mine and get something sorted out?
    sounds like a deal to me, Jezza I will be in touch with you shortly.
    BTW I am looking at around 270 degrees duration, 9.5mm intake cam lobe lift, 8.5mm exhaust lift
    but I am still undecided
    same, i keep wavering between 270 and 290 haha
    queensland
    I would never used welded cams unless it was the absolute last resort. All of the issues with flaking etc happen. --its just a matter of time. I have several customers asking for FE cams but none of the usual billet suppliers are interested, because of the low volume and gear problems. I need orders for about 10 sets to get overseas suppliers interested in talking. it took years to get the 3SG billets which we now take for granted. They are now so cheap, we would never dream of welding up a 3SG cam.
  1. [warning] TRD 272degree cams for 4age
    By progkamol in forum Tech and Conversions
    Last Post: 19-07-2006, 09:48 AM
  2. Whats the diference between these 7m cams?
    Last Post: 18-01-2006, 03:15 PM
