Results 1 to 11 of 11
Thread: MX83 Undercar Bush Kits ???
    Junior Member Grease Monkey slydin-cressy-style's Avatar
    Default MX83 Undercar Bush Kits ???
    Hi guys
    Im just wondering if anyone knows of a place where i can get an entire undercar bush kit for an MX83 Cressida?
    Doesnt have to be urethane even though it would be great if they were availible
    Im looking at replacing all the bushes under my car
    Josh
    Last edited by slydin-cressy-style; 12-10-2007 at 09:47 PM. Reason: Correcting information
    SUPPORTING AUSTRALIAN PERFORMANCE PRODUCTS...
    TURBOSMART MICROTECH JUST ALLOY RADIATORS
    THANKS TO:
    - ALL TRANSMISSIONS - IMPORT AUTO PARTS
    - P.I.T.S - PLATNIUM AUTO CARE
    Default Re: MX83 Undercar Bush Kits ???
    Super Pro probably make most if not all of the bushes for what you want. Nolathane is a brand of bush btw. They are actually a urethane bush as are Super Pro. There was also a thread on the Nolathane bushes disintegrating and not lasting a very long time. The Super Pro bush was also recomended as being a superior bush.
    Forum Sponsor Conversion King
    i dont think you can get super pro for mx83 (they may have a couple but not all) you will probly have to send Fulcrum (QLD) the orig ones and get them custom made.
    linden
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Linden's right. SuperPro only make a couple of bushes. I think it was radius rod and swaybar, not sure though.
    You can probably still get all parts through Toyota. Bit exxy though.
    Montrose
    I used the SuperPro (or was it Noltec?) radius rod bush, used generic sway bar bushes, and made the front lower arm ones. Rears also seem a bit hard to come by, they are also for MA70s etc.
    Don't waste your money on urathane bushes for anything other than sway bar bushes.
    Genuine rubber is a far superior bush and it wont damage any suspension components.
    act
    check with your local dealer you will find that they are all avaible in aust except for the rear suspesion member bushs that hold the unit to the body they are ex japan i have just sourced them all for a mate
    back from the dead.
    Have to change the front radius rod bushes in my mx83 Cressida. Have rung the local suppliers around here that do Nolethane, Noltec and Super Pro and it appears that no one makes them.
    Here is 2 pics of what I have. Just checking if I only need the piece in the first pic or are you supposed to get the whole bush assemble out of the chassis? If so, how the hell do you do that?
    Thanks
    Chris
    QUICKEST 1JZ'S IN OZ
    Adelaide, SA
    Takai's guide on www.toyotacressida.net
    http://forums.toyotacressida.net/for...ght=radius+rod
    Also, SuperPro definitely do make them. Ordered some not long ago.
    From the SuperPro online catalogue:
    Part Number: SPF1324K
    Location Description: Strut Bar To Chassis Mount Bushing
    Important Instructions: Re use original washers
    Number of Kits Required Per Vehicle: 1
    Single Kit Contents: 4 Bushings, 2 Inner Tubes
    Suspension Location Applied To: Front
    those things are a fucking **** to do, i did them a few months back.
    if you need any help let me know, but maybe you are smarter than me.
    Hmm...not looking forward to it. I have never done these type of bushes on any car so I know SFA!
  1. Castor Rod Bush Replacement on MX83
    Last Post: 23-11-2016, 03:41 AM
