I just had a few thoughts today.
The way i suggested to mount the shock on the diff using a trailing arm style mount might not work as it wont allow the coil over to pivot. Although at the same time im wondering how much it moves anyways since the stop is just a shaft and two bushes which dont move a whole lot anyways.
An even better idea is i saw some inverted shocks in some other thread. If you used these you could mount the coilover with the spring on the bottom and then the shock would clear its cavity. Once again though i think this would interfere with the diff.
Depending on the OD of those hot rod style coilovers with the two eyelets for mounting you could always weld a mount in the shock cavity and run a bolt in the top.
If diff clearance is still an issue with anything the mount could always be moved towards the back of the car a little more.
Ninja edit: The TTT coil overs dont run a keeper spring (correct term) either?
Nothing is a PITA if you're looking for a challenge
