The RA2x item has an adjuster and the shaft goes through the clutch fork.
The RA40 item has no adjuster, but a mushroom head. The clutch fork does not have a hole in it, so the RA2x item will not fit. RA40 item may not have a long enough (or short enough) plunger to suit the RA2x clutch fork, but I have not tested this... as I have not had a need.
Clutch lines connect the same. I too would have thought them to be interchangeable, but found out when purchasing new slave cyls over the years that they are different.
