Results 16 to 19 of 19
Thread: How to remove 4AGE crankshaft timing pulley?
    Jan 2010
    Default Re: How to remove 4AGE crankshaft timing pulley?
    For the information of anyone searching this:
    Just grind abit of the arms and it fits sweet
    WTB 15'' Rims
    20v AE82 Track Car - WP 1.17.7
    20v AE82 Street Car: Going Really Well
    Falcon ute, Slippin auto & a worn steerin rack
    Jun 2008
    Try tapping it forward with a wooden mallet, then pull back.
    Also, is that $40 for the pulley genuine Toyota???
    Junior Member Grease Monkey rick q's Avatar
    And when you get it out [I drilled and tapped], check that the Woodroffe key isn't sitting on some rust.
    Mine was, making the key a little high, and that seemed to be a good part of what was holding the pulley on the crank.
    Cheers ..... Rick Jones
    Fraser Clubman
    yeah the new genuine pulley was $40.
    I ended up using an angle grinder to get the 4age one off.
    Funnily enough I just pulled off a crank timing pulley off my 3sgte last night. I made up a puller for this as it already had two threaded holes for a puller. You need to pull evenly so it doesn't bind on the crank. I also heated it a bit and sprayed liberal amounts of wd40 on it the day before. There was a bit of rust under the pulley which was causing it to stick.
    The most important thing to do is take your time, pull evenly and use penetrating lubricant.
    Last Post: 12-07-2019, 05:11 PM
  2. Crank timing pulley timing belt guide, fixed or spinning?
    By Howieau in forum Tech and Conversions
    Last Post: 27-09-2007, 06:06 PM
  3. Need info about 4age crank pulley
    Last Post: 26-07-2006, 07:48 PM
  4. 4AGZE - EA Falcon Pulley Mod
    By TooF in forum Tech and Conversions
    Last Post: 15-05-2006, 12:23 PM
  5. RWD 4AGE Timing issues.
    By Rallystanza in forum Tech and Conversions
    Last Post: 11-01-2006, 09:03 AM
