Results 1 to 15 of 21
Thread: silvertop 4age
    Default silvertop 4age
    As time gets closer the list is slowly gettin smaller on my new race car.
    but now i have a dilemma i need some help on. i ordered for my S/T 4age a set of leads and timing belt and half a dozen other things but they all dont fit!!!
    i did a little research and found that i have a motor from an AE92, not the AE101 as i have read about every where else...
    is this motor good or bad. any difference?
    more to the point is the wireing diagram's the same for the AE101 to the AE92????
    Default Re: silvertop 4age
    ae92 vs. ae101
    16v vs. 20v
    single throttle vs. quad throttle
    yes but all the items that im buying for the ae101 are all different to the motor i have. yes it is a 20v motor. for one the timin belt for the ae101 s/t has 97 teeth and is 25mm wide. vs mine is 111 teeth and is 19mm wide. plug leads were too long. dizzy cap is different and rotor button om mine isnt a button its a disc... so on and so forth
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    AE92's didn't come with a 20V
    Junior Member Backyard Mechanic M.J.H's Avatar
    The silvertop part nr is 13568-19035 The silver top and black top motors have a different timing belt. The blacktop belt is about 3 mm wider and is shorter, having only 110 teeth instead of 111 for the silvertop. The part number for the blacktop belt is 13568-19185 .
    There ya go.
    What I was told for the Toyota part numbers for the timing belts on the 20V.
    My sig has been pruned as it was over 5 lines long.
    Mad****** Grease Monkey FASTFOO's Avatar
    vic
    sounds like they gave you 7AFE parts from us model
    vic
    oops aus model
    oregon
    Hmmm, I think what wilson 610 is saying/asking is he believes he has a very early(AE92) 20V... He says it is a 20V(tough not to distinguish a 20V) and yet it uses different parts....
    I went through all the info I have and I found nothing that said AE92 20V. Now, I do show SOME info showing the AE101 20V beginning in January 1991. The AE92 was also available in January 1991... so might there have been an interem 20V for the AE92??? Having worked in the Mustang restoration field, I know there were odd short run cars that aren't always recorded by history.......
    Aug 2007
    don't know about ae92's having a s/t but if they did, i doubt that toyota would change it that much in the 101.
    If they've given you a wider/shorter belt then my bet is they've given you GZE parts
    the 20V was not available in the AE92 at all. It came out in the AE101's in 1991
    The 97 tooth belt is too short and too wide to be a 20V or 16V 4age belt. From memory the 16V GE belt is 114 teeth and ~20mm wide.
    Junior Member Backyard Mechanic KARNAGE's Avatar
    I just got my timing belt for the 20valve cant remember exact number of teeth but that sounds wrong to start with. as it is to wide as well.
    blacktop timing belt is 110 teeth x 21mm. Gates T1567, Gates also has a 110x20.7 belt for a BMW 1.6i motor... T910
    The silvertop belt is 111 teeth and 19mm wide, a Gates belt for a camira fits, T081
    The 16V belt is 113 teeth and 19mm wide, Gates T176
    Insert whitty comment her Automotive Encyclopaedia blacktop's Avatar
    Aug 2006
    You either have a 20V or 16V but you definitely have the wrong parts, so take them back and tell them they ordered you the wrong shit and demand they get the right shit in
    right now i have got the correct timing belt... the next problem was the leads and dizzy cap.
    the ones they have got in are 90 deg outlet but only 2 bolt holes that hold it down not three...
    act
    i mibht be able to help have a look at your dist assy and send me the part number of the dizzy the toyota number should start with 19100 possible end with 16270 if you can supplie that i will come back wth all the correct pnc for you
    Last Post: 17-06-2008, 08:53 PM
