is it the shocks knocking or the strut tops? one is cheap the other isn't.
linden
hey guys as some of your know i got my mz20 soarer running after 2 years of slow modifying and cause the car has basically sat my tein n cusco coilovers sometimes make a knocking noise so i got told need rebuilding
so where is a good place to go??
linden
Originally Posted by WHITCHY
i have no idea so far , havnt driven car enough to know
ill try find out
but anyway which is the cheap one
try to guess
are you sure all the bolts and buts are done up tight?
were they new or fuc... i mean.. second hand from an importer?
were they ok before the car sat?
basically work out if it is the pillowballs knocking.. or the shock insert (if there is one) is buncing in the tube.. or if they are bottom adjustable.. it isn't bouncing off bottom etc..
who told you they need a rebuild?
the guys who do bilsteins (near tempe) are meant to be goodbut dunno if they touch the cheaper stuff...
ill check the bolts tomz
but im pretty sure they need building cause ive been todl heeps of times never to buy 2nd hand coilovers cause once they sit for like 6 months they do what mine have done
and car has basicalyl sat for 2 years, just been rolled around places
Sydney shocks should be able to help you out if they can be repaired.
Sydney Shock Absorbers
455-463 Princes Highway
(cnr Railway Road)
Sydenham NSW 2044
tel (02) 9516 1182
fax (02) 9550 3270
the coilovers are rooted, its like riding in a boatstrut tops are propbably part of the knocking noise to tho
no they aint, plus uve been in the car for 2 mins while ive been in it 4 moreOriginally Posted by IN 05 NT
unless your talkin about the other coilovers i have that i took out of the stripped soarer
err.... why on earth would coilovers get clunky when sitting there?Originally Posted by GU11TY
unless the shafts rust?
think abotu it.... how would a shock.. which gets absolutely punished when on the car.. suddenly die when it is left to it's own devices?
the myth probably comes from people buying absolutely fucked 2nd hand imported shocks but being told they were good when they left japan... (because, if you really want to know, most shocks that get bought by importers ARE fucked... thats why they are cheap....) so then the importer spins the story that the shocks get samaged by being left alone for too long.. but sorry, you can't have a refund.
if they clunk and no bolts are looses, it's rooted.
new coil-overs are not very expensivemaybe $1.5-2k for most of the TEINs?
well tehy can sieze if they sit for ages
gotta remember that most toymodders are povo sonsabitches though.... 2k is big dollars, haha.
I remember my teins kept smashing the spacer under the pillowball mounts.... caused knocking... eventually replaced it with a "custom" (high tensile nut ground to same dimensions) spacer and it never happened again after that.
Rebuilding coilovers shouldn't be that much.... i got quoted $80 each for new seals and $150 if shaft needs to be replaced.... this was an over the phone quote from some place in brissy.
(i know toymodders are povo.. otherwise they would be modding cars with higher base valuebut.. spend 5-10K on an engine.. and not 1-2K on shocks?)
how can they sieze?
you mean by rusting of the shock rods?
inside should not sieze.. unless they somehow got water in there and rusted?
or??
if 35 year old shocks that have sat for at least the last 5 or 6 years don't sieze.. why would coilovers?
well ill find out when i take the car to the drags on wed
will drive it around the car park etc and on the strip
im pretty sure its just seals but ill find out
how can seals clunk?
Like everyone has said check all bolts. Just last night i was driving and there was a nice clunk going on. It was getting quite loud so i checked the pillowball and where the shock bolts to the strut top was loose. It got rid of a noise that sounded like it was under the car too but it was only the top that was loose.
