Page 3 of 3 FirstFirst 123
Results 31 to 33 of 33
Thread: boost on twin screw chargers
    Default Re: boost on twin screw chargers
    sweet, found it thanks! (no details, but a pic)
    http://www.ihi.co.jp/ihk/seihin.htm
    a lot of th elength seems to be "not rotor"
    ooh that pic is bigger than i thought
    ok so here is the skinny....
    mazda S76 charger 1.65L/rev
    AMG S105 charger 1.6L/rev
    output of both : 18M^3/min
    they put out the same amount of air... the mazda charger is much less efficient than the AMG.
    the amg can push out 21M^3 and can run at 21000 RPM's
    the mazda already runs at 21000 rpms and puts out 18 M^3
    the S120 from the V8 mercedes puts out 3.0L/rev
    800 hp capable...
    the other 2 are 450 hp capable.
    mazda and AMG take 55 hp to drive at max rpms.
    make sure you have a large intake to keep the heat down.
    how does this compare to the 1200?
    The Supreme Backyard Mechanic
    Just the lower comp ratio makes the amg unit more suitable..... problem? alot more rare and expensive!!!
    just thought i'd put it out there that my sc arrived about a week ago.... now i need an engine to fit it to... good times!
  1. Turbos 101
  2. Autronic SMC boost control help
    Last Post: 27-08-2006, 11:16 PM
  3. Boost Leak Tester
    Last Post: 01-06-2006, 12:25 PM
  4. wiring up a turbosmart duel stage boost controller?
    By -=DV=- in forum Tech and Conversions
    Last Post: 15-03-2006, 04:53 PM
