Results 16 to 25 of 25
Thread: what can i use out of a JZA70 half cut into a MX83??
    OneJayZee Grease Monkey bungs's Avatar
    Default Re: what can i use out of a JZA70 half cut into a MX83??
    Quote Originally Posted by Hengsta
    if i do get a mx83 i will do it properly will try and source for the orginal mounts not the JZX90 ones
    Meh. Works fine for me, engine sits perfectly in the bay. There's no chance the engine could sit any further back or else it'd hit the firewall. The radiator hose fits perfectly, the tailshaft fits perfectly, so I fail too see how it sits further forward then any other mounts would.
    There was a thread on toyotacressida.net that showed the differences in engine location within the x83 bay when using x81 or reversed x90 mounts.
    Just for reference here's pics of mine. Yes my rad support is a bit mangled..
    Western Aus
    ive got a JZX81 converted mx83 in my driveway, if needed, i can take needed measurements?
    Western Aus
    but they pull on the rubbers and snap them in about 3 months with agressive driving.
    ive replaced 3 sets in the same car.
    linden
    i assume your talking about rubber engine mounts?
    new or second handies?
    standard or aftermarket equivelant?
    ive only ever used Ezra's (Byteme) mounts, i doubt they'll have the same issue.
    I've not compared the angle between the JZX81 and reversed JZX90 mounts, but I do know if either is used with the early MX83 crossmember which has more angle on the mounting plates, the mounts will be stretched and tear through.
    Quote Originally Posted by JP
    I thought it was common knowledge that you have to use a jzx81 crossmember OR a series 2 mx83 crossmember (which are identical). If you somehow managed to bolt any sort of mounts to the series 1 crossmember then no wonder the rubber is stretched lol.
    Junior Member Automotive Encyclopaedia Hengsta's Avatar
    sounds good guys cheers for all the info.
    so the x81 same as x90 mounting them on back wards?
    -Sleeper 2J + R154 X83
    -GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
    Western Aus
    i wouldnt say its the same, but similar enough to work, yes.
    Cheers mate.
    will let every body knows what i will get
    much appreciated for the help
  1. Twin C12a question from jza70 half cut
    By zork in forum Tech and Conversions
    Last Post: 18-01-2007, 03:14 PM
  2. MX83 Grande with Jza70 Auto
    By nemesis86 in forum Tech and Conversions
    Last Post: 22-09-2006, 08:58 PM
