Results 16 to 18 of 18
Thread: 'Built' 4AGE starting point
    Default Re: 'Built' 4AGE starting point
    ohhh nice, cheers for the link, will deffently have a good look at them
    Got your ute back Nath Grease Monkey 75Ta22LT's Avatar
    Cams - http://www.tighecams.com.au/
    ch-ch-check it out...
    running 300deg with 80/20 overlap on 16v
    gets going at about 6 grand
    oregon
    apologies here... USA 91/92 octane is pretty much it. Also vehicle emissions.....
    By all means building what would be an "off-road" engine here in the states.... Very simple... begin with the 20V block... the OEM crank is fine to 9k... over 10 look for a Formula Atlantic crank. The TRD Bible has ALL the specs in it to build their N2 engine. It is written in Japanese AND English with all the porting info listed. Once the head is done... I'd measure the combustion chambers and do some calculating on compression ratios. Find a GREAT engine management system, there are a few, the more capable the system, the more extreme you can run compression, cam, and ignition timing, You may want to lighten the crank some, a quality machinist can lighten the crank without hurting the integrity of it. The OEM later style oil pump(90-95) will work to 9k, again... over 10 and you may want to look toward Formula Atlantic dry sump stuff.
  1. 4AGE head on 4ac block
    By Dylan_ae86 in forum Tech and Conversions
    Last Post: 09-05-2006, 08:33 PM
  2. big port 4age comparisom
    By General_Bupkiss in forum Tech and Conversions
    Last Post: 03-04-2006, 09:12 PM
  3. Solid Lifters (1SZ) on 4AGE: Conversion Guide
    Last Post: 16-03-2006, 10:53 AM
  4. Replies: 0
  5. 4AGE not starting correctly 5-10 times, then starting correctly?
    By phrostbyte in forum Tech and Conversions
    Last Post: 30-01-2006, 06:55 PM
