umm.. how good handling? you can play around with stock design, or you can transplant in KE20 front end.. or you can get a bit more tricky and put in rack and pinion. rear end if you want to go past the leaves requires a lot of work.
KE10 is not so easy as it has smaller track than other toyotas, and does not share suspension parts with KE20 or later (although KE20 column, and later brakes do fit)
wheel and tyre?? whatever fits over the brakes... as a rough guess, 15" is abotu as big as you want to go.. you should be able to get good sized brakes under them. tyre.. 195 MAX
gearbox.. whatever goes with the engineT50 for NA 4AG, W5X for abuse or FI? depends how you drive.
