Results 16 to 30 of 32
Thread: How do I correct my SpeedO.
    Default Re: How do I correct my SpeedO.
    I have since purchased this car, is it adviseable to take it to a place like VDO or replace the gears in the speedo unit itself ? (may be cheaper?)
    Photographer and Backyard Mechanic Rinmax's Avatar
    Cheapest solution - crack open your speedo, and with a black marker cross out the numbers and right them in their new spots. Replace speedo, problem solved at minimal cost.
    "It's an ingenious solution to a problem that should never have existed in the first place." - JM
    "A Ferrari is a scaled down version of god while a Porsche is a Beetle with mustard up its bottom." - JC
    sounds ghetto enough to work, as a last resort.
    im looking into replacing the gears in the speedo first ;-)
    I've heard before that some instrument places can recalibrate the speedo and then you don't need to stuff about changing the drive gear for it. Ring around, there's a place here in Adelaide that claims to do all sorts of wonderful things with speedos.
    http://www.adelaideinstruments.com.au
    Being in ACT i have rung a few places.
    they have said $150 for a recalibraion or $300 for a ratio box to convert the signal. Its either one of those or change the sender in the gearbox itself and me not having any tools here in ACT makes it hard to do it myself
    You can change the speedo sender, it should be bolted to the side of the box, change it to something that had the same rear diff ratio as you have. Hope that you don't have to change the corresponding gear inside the box as well
    If you're never planning to change the diff, $150 to recalibrate the speedo sounds good.
    research has lead me to think that a change inside the box is needed if I am going to change that I may as well get a ratio box as it will cost the same time/money as I have very little tools here currently (just moved!)
    Casual Carport Converter Grease Monkey mux's Avatar
    Feb 2007
    Kedders,
    Like I said mate... i'm happy to help out. Time, Tools and such.
    I'm still looking for the right ratio diff and other means...
    Actually I should be able to help, I've got the original Auto box in the garage.
    we'll probably have to pull it apart to get the gears out...
    Leave it with me
    MUX
    surely you can just change the speedo drive gear in the gearbox?
    find a few different cars with that box and see what gearing each one runs. with the gearboxes ive played with. you unscrew the cable, undo the one bolt that holds it in, and the outer slides off and the ratio is etched into the shaft. might even crossbreed to different gearboxes.
    half a day at a wreckers might get u a few different units to try...
    no rush mate im still finding out what are available options there are ;-)
    if you get a chance id still welcome your help!
    edit yeah its not like im scared of tyring things its more I dont have the tools nor the work area atm with my unit
    Junior Member Grease Monkey rick q's Avatar
    The only other thing to be aware of is that when your speedo is recalibrated, it doesn't change the accuracy of the odometer.
    After the speedo is fixed, the odometer will be reading the same error (i.e. 10% further than you've actually travelled or whatever the original speedo error was!!) It's important to some - but not too others!!
    Cheers ..... Rick Jones
    Fraser Clubman
    very true. This however is a modded mx73 i doubt ks are important, well they arent to me!
    rick q, depending how u calibrate the speedo that is. if the drive gear is replaced then the odo will be fixeded
    cheers, andrew
    I was trying to figure out Rick q's theory as well.
    the odometer & speedometer both work off the same input. If one's out, so's the other.
    Get the speedo reading accurately & the odometer will be accurate(ish) too.
    What happens is :-
    You've changed the gearing on the cable drive at the gearbox to the closest thing you can get. However the speedo is still out (for the sake of the argument, let's say it's reading 10% fast because the cable is still spinning 10% faster than it should be to get an accurate speed).
    You take the speedo to an instrument technician, who adjusts the spring tension on the speedo needle. This then makes the needle sit in the right spot so the speedo reads correctly. However, the odometer is direct driven by the cable (which we've just said is running 10% too fast). That means the odometer clicks over 10% faster than the distance you've actually travelled - even though your speedo is doing just fine.
    Hope that helps clear it up - I've just gone through the research bit because I've got this same problem on the Clubbie after changing the diff.
    Fraser Clubman
  1. How to fix your speedo the factory way ...
    By Sprinter in forum Tech and Conversions
    Last Post: 29-04-2019, 05:35 PM
  2. you can light up your speedo with LEDS
    By puzzle man in forum Tech and Conversions
    Last Post: 21-03-2006, 10:34 AM
  3. Speedo and Odometer questions
    By Big T in forum Tech and Conversions
    Last Post: 04-12-2005, 05:43 PM
