RA23 will want a mid sump, unless you have a TA23 crossmember which is front sump.
MV Automatics will sell you a box which allows you to manually shift the auto so you can get rid of the OEM electronics entirely.
have a couple of quick questions. I am about to purchase a 1JZ with auto to put into my ra23. My question is about the auto behind the 1JZ, now i do believe i will need the cumputer to run the auto, i have a MoTeC which will be doing most of the work. Is there a way around not having to wire up the stock computer, something was mentioned to me tonight from the guy who's going to sell me the motor that I could get a hold of a "stand alone computer" will this run the auto without having to install the stock computer??? Just dont wanna have to have a million wires floating around the engine bay.
Also I have read sheepers thread on how to install this gear, it sais he is using a mid sump, avaliable with this motor is a front or rear sump, im guessing i would need the front sump? does someone know what the mid sump is out of? and im not going rack and pinion steering.
RA23 1JZ VVTi 373hp - SOLD
12.4 @ 110mph
THE EVOROLLA262.9hp - SOLD
Norbie!
www.norbie.net
so does that mean i'll have to go back into 1st everytime I stop at a red light? wouldnt mind an auto that does all the work for me, this thing will be driven everydayOriginally Posted by Norbie
12.4 @ 110mph
Can I ask why youre not going for a manual?
Project Soarer II - Sold
Evo 5 - The silver fruitbox
one day ill get to finishing the toyota auto gearbox shifter...
it should have auto and manual modes.
hello
Well manual shift implies that yes, you will have to manually select gears.Originally Posted by Jordan 76
If you want proper automatic control I don't think there's much you can do except wire up the factory ECU with the Motec hooked up piggyback style. I suppose you could use some old hydraulic auto (people have used TH400's behind JZ engines before) but this isn't a cheap or easy option.
Norbie!
www.norbie.net
Mr 1jz - im going auto cause the car is already auto as stock, ive always had manual car's and would just love to have a lazy auto and for those long cruises. I have all the gear to swap it over bar a r154 which would be the only option, dont like the idea of the w5x behind something that has huge potential. Im sure that one day the car will get a manual swap, probably the day my probation ends. (and thats a long time from now)
Norbie - damn i was hoping to not wire it all up but thats what im gonna have to do i guess, cheers for the info + rep
12.4 @ 110mph
dont fool yourself thinkin you cant lose yer license with an auto![]()
no but its harder to loose it with an auto, manual cars i just cant help myself
12.4 @ 110mph
so if i get an mv automatic shift thing and am shifting gears manually all the time, wouldnt that shorten the life of the auto box?
12.4 @ 110mph
does anyone know if the 1jz (out of the soarer) runs an air flow meter?
12.4 @ 110mph
none of the non vvti 1JZs have air flow meters. all map sensored
hello
cool, next question i have a custom tail shaft in my 1g 23, it runs a w58 box am i going to have to change the yoke???
12.4 @ 110mph
Hey is the r154 the better gbox option behind the 1jz as oposed to the w58?
Just curious...
Jase
um hell yes, r154 can take up to 1000hp, i have known cars that run close to 500hp with a w5x but they dont last too long
12.4 @ 110mph
