there will be some movement, due to needing clearance for fitting.
here is a pic of the one on the 1UZ. as you can see there is some clearance between the trigger wheel and the keyway.
I'm not sure how much clearance is too much though...where are you measuring the few millimetres? if thats at the outer edge of the trigger wheel (i.e. at the teeth) its probably insignificant. (do you mean few millimetres total movement, or few mm in each direction from the middle, i.e. total movement is 2*few mm? If its the latter id be concerned...)
