Results 16 to 24 of 24
Thread: Does thi CT-26 look hi-flowed?
    Default Re: Does thi CT-26 look hi-flowed?
    A hiflow on a 3sgte gives you a little bit more punch in the mid range, slightly less if any difference in lag, and it holds boost closer to redline unlike the stock ct26 which dies in the ass after 5500+rpm.
    These are the changes i noticed from going from a ct26 JDM ceramic to a 50trim ct26 steel wheel..
    Linden - Aus delivered st185 3s's and CS edition st185 had a steel exhaust wheel from factory.
    Forum Sponsor Conversion King
    Dec 2006
    only ever seen JDM stuff.
    linden
    lolwut Grease Monkey
    Apr 2008
    melbourne
    old thread i know
    but i just purchased a CT26 high flow that looks to have a 2.23" 57trim T04e compressor wheel and clipped turbine blades to allow more flow.
    just curious as to how much power these turbos are good for?
    i purchased it as the guy said it was a T04e turbo, but obviously its a fair bit smaller.
    i bought it to put on an EB falcon 4 litre with an aim of 5-7psi or 180-200rwkw at 4500-5000rpm
    i've been told that i could get away with a T3 (which has a smaller turbine and much smaller comp wheel than the turbo i have) but i think the turbine housing flows more - the CT26 looks tiny!
    so i guess what im curious about is will this turbo be ok on a 4ltr?
    i know its small but i dont see the point in going for a turbo thats larger than i need it to be if i can get away with a small one
    I got 225 rwkw on my 7mgte with a 57trim wheel.
    4 litre will make the turbo spool really well, probably choke it up top, get a turbo from a xr6 turbo, perfect!
    RA23 - Twincharged
    JZZ20 - Daily
    Apr 2008
    melbourne
    the whole setup so far has cost me a couple hundred lol
    i got the CT26 for $30 cause it needs new seals ($60 for a rebuild kit)
    but if people are making 220rwkw with them then i cant see why i cant make 180rwkw.
    doesnt matter what engine your using (within reason), 220rwkw should require a certain amount of air and will generate a certain amount of exhaust gas.
    the 4l is a larger engine but it will only be spinning to 5000rpm max, so i'm hoping i might get away with it.
    there was a turbo falcon done by dealers in the early 80s and 90s that used a T3 (which as a said has a smaller turbine and much smaller compressor wheel) so in theory should work lol
    but yeah, will proly see boost at 1500rpm or something silly
    Tasmania
    you will need to highflow a ct26 to make that much snort. Max on a stock ct26 is around 180 atw so you might be ok, it'l be damm responsive.
    As a comparison the ct20b (turbo off the last model gtfour) on mine made 200 kw at all 4 wheels at 20 psi.
    1973 TA22
    Apr 2008
    melbourne
    yeah the CT26 i have has a clipped rear wheel and 57trim front wheel.
    sounds like it might work out. it will be interesting lol
    Gearwhore. Backyard Mechanic
    Oct 2008
    Quote Originally Posted by misk View Post
    Goodbye all your top end. T3/T4 is what you want for a low boost setup, or do a twin setup with T28's
  1. I have a Hi flowed CT26 and want to upgrade to another turbo..
    By tai_180sx in forum Tech and Conversions
    Last Post: 14-12-2006, 04:35 PM
