Results 16 to 22 of 22
Thread: 4age 20v - When are heavy duty valve springs required?
    Default Re: 4age 20v - When are heavy duty valve springs required?
    do these problems extend to 16v engines?
    Just got a part number for TODA valve springs.
    Full set to suit 4age 20v : 14750 - 101 - 000
    Quoted $260+post
    They have to come from Japan though....
    New Zealand
    TRD still available.....
    p/n 10309-AE001
    please, no more PMs!
    what would they cost revhead?
    Penrith BC
    Quote Originally Posted by Celica RA45
    this is for edd
    You will find that you cant get much more duration before the VVT mechanism stops working. It relies on the camshaft accelerating off the back of the lobe to click it into the advanced position. Once you get to a certain duration the cam is pickup up the next cylinder before it falls off the previous one.
    i thought you found the vvti issue was sorted after something with the oil? youre running higher duration cams than me glenn, and your vvti still works?
    ../delete/ban
    tech moderator
    Melbourne Victoria
    ed this is vvt not vvti and its not worth using vvt on the 20 v when you go up in duration and lift ,as middle valve gets in the way and its hard to fly cut it any deeper
    Penrith BC
    ah my mistake - thanks mate
    ../delete/ban
    tech moderator
  1. changing valve springs 4AGZE
    By nick.parker in forum Tech and Conversions
    Last Post: 08-11-2006, 10:03 AM
  2. 4age gearbox bolt specs required
    By -GT- in forum Tech and Conversions
    Last Post: 24-08-2006, 05:33 PM
  3. Your suspension & you...
    Last Post: 23-05-2006, 07:41 AM
  4. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 01:05 PM
