Results 1 to 5 of 5
Thread: Autronic SM4 thermo fan control
    Teh Massif Dong Carport Converter BlackSupra's Avatar
    Default Autronic SM4 thermo fan control
    Just wondering if anybody has wired up thermo fans to their sm4.
    Is it using the pink wire of output 5 as the trigger?
    Does the wire trigger to ground?
    How do you go about the setup within the software?
    Jan 2007
    Default Re: Autronic SM4 thermo fan control
    Refer to manual. If you did not get a manual with the SM4, go back to the dealer and get one.
    It depends on how you set up the software !
    Forum Sponsor Conversion King
    Dec 2006
    ill have to look at the diagram but yes it triggers to ground.
    just set the output your using to trigger at the temp you want.
    linden
    ask moss when you can meet him here and ill set it up for you.
    Quote Originally Posted by rms
    There wasnt a manual when i bought it!
    I assume it just uses the existing coolant temp sensor for the temp reading?
    Does the trigger wire just connect to the ground terminal of the relay?
    Dec 2006
    there still isnt an AUTRONIC manual just a ray hall one that has some backward shite in it that can confuse ppl. (check his dwell recomendations for smart and dumb ignitors)
    dong, start harassing mos now as he'll take foreva
    linden
    ninja edit: yes to both Qs
  1. What ECU do you use?
    Last Post: 06-12-2007, 10:42 AM
  2. Microtech Or Autronic???
    Last Post: 18-06-2007, 03:44 PM
  3. Autronic SMC boost control help
    Last Post: 27-08-2006, 10:16 PM
