Now when you get to the 15uF nichicon cap, things get a little tricky. Get your 10uF and 4.7uF caps, and before you fit them to the PCB, solder the legs together in parallel. This effectively makes a 14.7uF cap!
Trim off the excess legs from one of the two, so that you only have one pair of legs left.
Now fit them like so:
Now... because of the harsh vibration and whatnot your ECU will endure, its probably a good idea to use some hot melt glue to stop this multi-cap from vibrating and breaking the solder joint.
Now where i had that leaky cap, the PCB track was ruined. So i "replicated" the PCB track using a piece of wire. You may not need to do this, but i'm over cautious.
Now... after replacing all the caps, i gave the PCB a quick coat of PCB laquer, NA1002 from Jaycar.... let it dry, and put it all back together.
BANZAI!!
