Results 1 to 9 of 9
Thread: 3tgte ignition and timing
    act
    Default 3tgte ignition and timing
    just neet to know about 3tgte time and and wat order do the leads go..
    i have marks on my distribertor cap the are go1r,2r,3r,4r,and 1f,2f,3f,4f
    so wat order do they go in
    Default Re: 3tgte ignition and timing
    Have a search before posting, the first thread i skimmed through came up with your answer
    Firing Order: 1-3-4-2
    Use the power to find out the rest.
    act
    i have been searching but here is like 10 diff firing orders that i have found so just so one to well me the right order and it has 8 plugs so 1-3-4-2 will work for thr frist 4 bit wat about the rest
    thanks
    User Conversion King
    NWA
    seems obvious to me but i may be wrong.
    R = rear
    F= front
    1 = cylinder 1
    2=cylinder 2
    join the dots
    hello
    Surely its more complicated .
    Have a stab, obviously the numbers will go together and id take a stab in the dark r for rear and f for front as brett has pointed out, not that front or rear should matter unless one fires less ms on the exhaust stroke. now you need to find which cylinder is one, have a stab in the dark, it wont damage anything if its wrong, it just wont start, or search.
    NWA
    front most cylinder is always 1
    looking at top of engine.
    4R
    4F
    3R
    3F
    front of engine here
    hello
    act
    yeah i just didnt really want to get it wrong just in case i might blow something up
    firing order 1-3-4-2 and f= front and r = rear all good thanks for the help..
    NWA
    you dont even have to consider the firing order as everything on the dizzy cap is labelled to plug straight in
    hello
    act
    yes i see now thank
  1. Toyota Distributor and DLI Ignition Systems - explanation and guide
    Last Post: 14-11-2010, 02:42 AM
  2. 4agze Ignition Timing problem
    By Poggy in forum Tech and Conversions
    Last Post: 04-05-2007, 10:27 AM
  3. Replies: 0
    Last Post: 20-07-2006, 01:18 PM
