Results 1 to 11 of 11
Thread: Electrical troubles - DIODES
    Default Electrical troubles - DIODES
    I am in the process of installing an alarm and some other electrical stuff into my RA23 and am having big problems getting things to work, i'm pretty savvy with electronics but would just like to know if anyone knew where i could get some diodes to help me with the installation. I'm pretty sure the problems i've been having could easily be fixed by using diodes but i cant seem to find any suitable for the amount of current thats drawn from a cars electrical system. The only thing i can think of is using some from an alternator but i dont have an spare alternator and would rather use new items.
    rob
    Default Re: Electrical troubles - DIODES
    car power is DC, diodes convert AC to DC
    How much current are you talking about?
    Quote Originally Posted by Screamn_Sleeka
    That is one use of many...
    not sure how much current probably no more than 20amps i would say
    Thats a decent amount...
    What problems do you have that you think a diode will fix?
    What kind of car alarm has a current draw of 20 amps??
    My guess is you are trying to avoid "feedback" from your door trigger wires, or your indicator "flash" outputs.
    Indicators = Use 6A1, 6 amp, ZR1041
    Door trigger wires = use 1N4004, 1 amp, ZR1004
    Both available from Jaycar, part numbers listed above.
    yeh trying to eliminate feed back so i can get the door triggers to work properly, 20amps was just a very rough estimate as i was just going by what it says on the fuses for the alarm, thanks for your help witzl very appreciated
    Rob
    Wow! pack of 10
    I've always used 3A diodes (1N5404 - Jaycar ZR1014) for indicators, and they seem to be supplied with almost every alarm (or used to be). Indicator circuits draw around 3.5A, but they seem to survive indefinitely (diodes can handle surge currents within certain contraints without failure).
    Otherwise there's the PX6007 6A diode available in single quantities (Jaycar ZR1024).
    Mos.
    Mos - yeah i've used 1A diodes for the indicators before, and they worked. The guy didnt complain within 6 months....
    I just suggested 6A diodes to be safe.
    Karl.
  1. mx23 electrical wiring diagram.
    By _gear2 in forum Tech and Conversions
    Last Post: 29-06-2007, 02:11 PM
  2. Camry, 3sfe electrical problems
    By MarkIIRx12 in forum Tech and Conversions
    Last Post: 17-09-2006, 10:57 AM
  3. Electrical Mayhem - how did I munt this?!?
    By ra23celica in forum Tech and Conversions
    Last Post: 12-06-2006, 11:03 PM
  4. Electrical sender unit for w58
    By RAd28 in forum Tech and Conversions
    Last Post: 17-01-2006, 06:24 PM
