Results 16 to 30 of 30
Thread: Basic 1GGTE into RA23 wiring
    Default Re: Basic 1GGTE into RA23 wiring
    pm replied, thanks heaps mate
    livin on the edge as a Grease Monkey Snyper's Avatar
    south australia
    ok, successfully completed the wiring of a 1ggte gen3 into ra23... anyone needing assitance just ask.
    Brendon
    Daily - Prado 90series
    Work - T908 620hp Cummins ISX
    Shed - 1975 TA22 2TG
    on that note, how do i wire in the alternator to the ra23 body loom, which wires to which?
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    Hung like planet Pluto... Backyard Mechanic Rcubed's Avatar
    QLD!
    Quote Originally Posted by Jordan 76
    http://www.toymods.net/forums/showthread.php?t=2705
    i'll check mine tomorrow
    QLD!
    ok i've looked what i did specifically for the 1G alternator in the 23. sorry i don't have photos as the wiring is in tape inside convoluted tube and i'm in Brisbane [away from home].
    the regulator has 6pins but you only need 3. looking end on at the plug with clip at top you need top right [black w/ yellow - IG], bottom left [white - Voltage sense] and bottom centre [yellow/white - CHG light]
    the alternator had a 3 pin round plug with 2 horizontal pins beside each other above a vertical pin in a "T" arrangement. again looking at the plug w/ clip at bottom. top left is IG [Black/Yellow wire] top right is CHG light [yellow/white wire] and bottom vertical pin is Voltage sense [white wire].
    so, for me, it was white-white, yellow/white-yellow/white and Black/Yellow - Black/Yellow . the large post marked B+ connect to battery
    hope this helps
    Last edited by Rcubed; 03-01-2008 at 02:20 AM. Reason: altn clip at bottom, not top
    Hmmm I'm going home to check this myself. I kept my fuse box and plugged the remaining two wires up to the regulator plug but kept the sense wire going to the fuse box I think.
    Now my charge light doesn't go off :S
    photo's would help alot, ive already tried a couple of ways, copying off the old 1g23 and hash23 gave me a few pointers and the charge light doesnt seem to go away. ill put up a picture as soon as my computer is fixed of my alternator wiring as what has been described isnt lining up with what I see. On another note anyone know who can re-calibrate the stock tacho to read the 1g?
    12.4 @ 110mph
    QLD!
    search is your friend
    http://www.toymods.net/forums/showthread.php?t=6300
    i drilled a 3mm hole in the back of the case in this location [circled bottom right]
    http://www.geocities.com/hot_buoy/my_car_003_copy.jpg
    that way with the case closed you can connect it up to normal wiring and get a small screwdriver in and adjust the pot down. you need an external tacho which will read 6 cyl input to calibrate [i have a tune up analyser which i've had forever].
    fuk yeah dude, ive been looking for that thread + rep
    12.4 @ 110mph
    QLD!
    alright - kids asleep, chores done.
    took some pics
    1977 celica wiring diagrams
    alternator plug - note correction above, clip at bottom
    Wires [from above] white wire is below
    Regulator Plug end
    Regulator plug from above.
    Green, bLue and Black/Yellow above
    White, Yellow, White/Black below
    1. There's no point arguing with an idiot. They'll just drag you down to their level and beat you with experience
    2. Don't argue with an idiot; people watching may not be able to tell the difference
    Quote Originally Posted by ta23-mbzq-nnr
    took some pics
    Regulator Plug end
    this didnt work when it was wired in the last celica only the 2 small yellow/ black wires were plugged in and the large white wire was on the power terminal on the alternator itself? any ideas?
    12.4 @ 110mph
    Is that your current setup? or your old one?
    The thick wire in the picture above is the voltage sense wire. Looks hooked up correctly.
    The yellow wire should go to one side of the charge light, and ensure that the other side of the charge light is the same as ignition (12v when key is on ignition and run, 0v otherwise)
    The black wire should go directly to ignition.
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    Junior Member Backyard Mechanic Hash_ra23's Avatar
    jordo, maybe your alternators dodgy?
    1977 RA23 Celica -> 1ggte conversion [SOLD]
    MA70 Supra 1JZ 5speed [SOLD]
    Current: IS200 1JZ VVTI 6 speed
    alternator is brand new and has been working a1 with 13.8 volts, even had a volt meter hooked up in the other car. thanks timbo, shall get the test light out and find the wires
    12.4 @ 110mph
    ok this did work, i just have to do something with the charge light which wont go away hooked the laptop up and 13.8volts thanks to all
    12.4 @ 110mph
  1. wiring basics!!
    Last Post: 03-01-2007, 06:25 PM
  2. RT142->1GGTE wiring help
    Last Post: 11-12-2006, 12:00 PM
  3. 7mgte wiring diagram similiar to 1ggte?
    By rollsy in forum Tech and Conversions
    Last Post: 20-11-2006, 09:49 AM
