Results 1 to 12 of 12
Thread: help with safc wiring to gen2 1g
    90 Millcrest st
    Default help with safc wiring to gen2 1g
    hi how do you get around the whole non resistor type tps of the 1g when wiring in an safc? The safc only registers different voltages when the throttle is either open or closed and i assume it needs to read it on a continuous basis? Anyone who has done this your help would be greatly appreciated
    90 Millcrest st
    Default Re: help with safc wiring to gen2 1g
    noones wired an safc to a gen2 1g?
    90 Millcrest st
    anyone? its relatively urgent
    What do you mean non resistor type TPS? It has a resistor section, and an idle switch. Methinks you've hooked into the idle switch.
    90 Millcrest st
    mm yeh thats what i thought, so i tried both IDL and PWS pins, one just gives me constant 4.5volts and the other switches from 0 to 4.5 volts when the throttle is around 80% depressed, not gradually like if it was a resistor. I was under the impression that the 1g TPS was just a series of switches, no actual resistor. Which would make sense as there are a total of 8 wires coming out of it..
    90 Millcrest st
    ok if the tps was a potentiometer type, there would be an output called VTA, and that identify the throttle angle. The 1g tps doesnt have that output... wierd
    Both my Gen2 and Gen3 TPS' have functioned the same. They have the idle one and the variable one. If yours doesn't, sounds like it's munted
    90 Millcrest st
    well one is variable, just not continuously as you depress the pedal, it just switches on and off. Thats fricken wierd dude
    90 Millcrest st
    heres the thread about the tps being a series of switches, not a resistor
    http://toymods.net/forums/showthread...ight=1ggte+tps
    Hmm, maybe it wasn't the Gen2 one I remember checking as well, the Gen3 is definetly variable. I'm using it now on my Adaptronic.
    90 Millcrest st
    ffs had to be different didnt they.. afaik the safc only needs the tps signal to differentiate between the high throttle map and the low throttle map, so i should be able to get away with the wacked out signals. Were you still trying to sell an XF throttle body by ne chance?
    Sure thing, check engine parts for sale.
  1. 4agte wiring
    By pro-16t in forum Tech and Conversions
    Last Post: 25-08-2007, 10:04 AM
  2. Replies: 23
    Last Post: 29-04-2007, 12:18 PM
  3. Microleb wiring assistance on 1JZ!!!11oneone!!11(LTX-12)
    Last Post: 23-05-2006, 11:27 AM
  4. 100kW 4AGE wiring diagrams
    Last Post: 15-04-2006, 06:03 PM
