Results 16 to 26 of 26
Thread: How many/much thread is adequate ?
    Default Re: How many/much thread is adequate ?
    Quote Originally Posted by 30psi 4agte
    Where is the best place to find longer studs ?
    Here
    http://www.niceproducts.com.au/
    for people that are thinking that 9mm is enough thread (like GU11TY ) if your thread pitch is 1.25mm, the nut will only be on 7 threads of the nut/stud, deffinatley not enough!,
    blake
    As a general rule the Australian standard for nut Capture is 1.5 x the bolt dia. This is to take up the slack for tensile forces in the bolt so the whole nut is being used.
    Simon
    Beige.... The new Black!!!
    the hybrid Backyard Mechanic Fish's Avatar
    western australia
    i'd take 3 threads showing past the nut as max.
    As for scrutineering if you plan on drag racing it have a look att he ANDRA rule book. They require open ended nuts and I believe the stud has to go all the way through and then some.
    Forum Sponsor Conversion King
    Quote Originally Posted by amichie
    these are the studs i use and most of the time the longer replacement studs actually have a .1mm larger shank so this should allow you to kill 2 birds with the 1 stone.
    linden
    For those looking at this and thinking about their street car... I wouldnt use open ended nuts on a street car as the dirt/grime/corrosion build up on the end of the bolt will make removing the nut after 2 years driving when you get a flat an absolute PITA.
    Race cars are a different kettle of fish, as you dont have as much crap coming up from the road, and you generally remove the wheels quite often to inspect/service the brakes/drivetrain.
    Linden, good to know that the NICE studs are oversized, that will be handy to know while doing my SA23 conversion.
    Jun 2008
    1.5 times is the correct answer. The idea is to have the stud break before the nut pulls off by shearing the thread. It's much easier to design because you use the stud root diameter. Also, if anyone has ever done technical drawing at school, the 1.5 is what they drill into you.
    Quote Originally Posted by petergoudie View Post
    UNBELIEVABLE TENACITY!!!!
    This man will undeniably be going places in the future!
    Two years & some change of research and calculations right here and exclusively released for the safety of Toymodders!
    Best old thread pickup I've seen in a while
    Jason
    PS have some + REP on me
    Junior Member Grease Monkey RPM016T's Avatar
    Quote Originally Posted by 30psi 4agte View Post
    Hey man, try Outlaws in Grote Street in the city or O.G speedshop on OG road.
    gt28714AGEKE15OM17SGoodi.
    S.A
    nah....... way to pricey.
    Ended up getting off of ebay. For $30 for ten. They cam zinc plated and all. Very happy with the quality.
    To be honest i wasnt expecting much for $30 but i was very surprised.
  1. The AW11 Brake Upgrade Thread
    By mullett in forum Tech and Conversions
    Last Post: 06-09-2010, 09:07 PM
  2. How to edit a thread title?
    Last Post: 11-01-2006, 09:53 AM
