Results 16 to 23 of 23
Thread: celica needing fuel pump
    Default Re: celica needing fuel pump
    Shine a light on what... the problem?
    As suggested above, timing or fuel sounds like the cause... youll have to do more diagnostics to work out the exact problem.
    Even if you cant find a working RA65 fuel pump (i find this *very* hard to believe), youll be able to use one out of another car with some tinkering.
    If the seller wont let you play with the car to work out the exact problem before sale... well its your gamble.
    Montrose
    My RA60 had a dead fuel pump, and a very similiar problem. I replaced the pump with the old one I removed from the Celsior (like most of the Toyota pumps, easy fit straight in place), and that fixed it straight away. Even a new pump will only be a bit over $100. Change the filter and clean the tank at the same time, and you should have a few more years of happy (thirsty, gutless!) motoring.
    Check the fuel pressure, ignition, etc. first though and be sure what the problem is.
    Bored d00d Backyard Mechanic H1TMAN's Avatar
    Jan 2007
    ok noob here,
    Checking ignition- distributor cap off and check if there is 4 sparks?
    Fuel pressure- I have no idea whatsoever
    Miss my Ma61
    Junior Member Backyard Mechanic Azzamk2's Avatar
    western aus
    dont forget doesnt it need a tyre replaced? and hopefully for your sake the engines not just worn out.
    Jan 2007
    to hell with it!
    I'm going to try and buy it + re-rego the car anyway.
    Save it from the wreckers.
    Miss my Ma61
    Jan 2007
    had it for 30 mins today.
    Ok the oil is a normal color
    i think there is somthing wrong with the ignition- When the car is running there is a clicking sound constantly going and it could be in a cylender.
    There also is a smell of fuel when the car starts up- i am not sure how much the car had but it went through a bit of fuel.
    It wont rev over 2-3k when driving when its cold but once its warmed up it goes very well - it seemed to warm up quickly too. in 10 mins it was at half way or just under.
    the air filter has a hose running off it that jolts when the car backfires this may have somthing to do with it-
    any ideas?
    Miss my Ma61
    Do a diagnostics check and see if there are any codes? if that ignitor is faulty it will show that in a code.
    Jan 2007
    well it should be arriving at my place around 12pm sunday- let the work begin.
    Miss my Ma61
  1. Replies: 20
    Last Post: 08-08-2007, 10:06 PM
  2. sw20 non turbo not starting (fuel pump, filter ???)
    By purple5ive in forum Tech and Conversions
    Last Post: 23-07-2007, 09:45 AM
  3. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 11:12 PM
  4. Mounting fuel pump (intank)
    Last Post: 24-01-2006, 10:49 AM
