Results 16 to 30 of 33
Thread: head gasket fixed, other issues
    Default Re: milky leaking head gasket
    thats a BHG.. if its full of caramel its time to push it into the shed and start pulling it apart.
    compression test came out like this.
    #2 120kpa
    #3 80 - 90kpa
    #4 10 - 30kpa
    start unbolting.. its obvisouly really odne a gasket or possibly a crack in the head itself.
    pull it off send the head off to the machine shop to check for cracks and machine. then asses wether just drop a second hand motor in or its worth fixing
    Hide Yo Kids Hide Yo Wife Carport Converter hamgatan's Avatar
    30kpa OUCH! sounds like bottom end is gone too...
    JZZ20 1988 Soarer GT Twin Turbo
    1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
    not nesecarily. i had a bgh on the 4ag and it had massivly blown out the fire rings and was only putting down 20 odd psi on two clys.
    yeah true. old jag i had was running 5 out of 6 cyl at normal compression.
    the last one had zero compression and would just bob up and down uselessly. problem was solved by replacing piston rings and gaskets
    Default Re: milky leaking head gasket, with pics
    got everything off and had a peek in side today
    the gasket is totally shat. and this is what the cylinders look like.
    whats the best way to get the coupe of bits of crud out? air compressor?
    dude.. thats just from condensation cover up the breather and you'll be right
    yup thats shagged
    but one bore has nicely been steam cleaned for you
    personally i tend to clean it with a scotchbrite pad and thinners. periodically blasting with compressed air to get rid of the crud.. remember safety glasses. blowing out bits of crud soaked in thinners is something you dont want in your eye.
    Default Re: milky leaking head gasket, distributor cap help
    so i pretty much have everything back together. just one problem. the distributor has no numbers on it and i dont know which lead goes where.
    theres 2 pulsar forums i've been trying to get onto but neither seem to work.
    whats the best way to find out which leads goes where?
    i assume the dizzy has some match marks so you know how to align it.. get #1 cyl at TDC. align the dizzy into place. work out which direction it rotates then hook up leads in the firing order of the engine. usually 1342
    Default Re: head gasket fixed, other issues
    ok i actually finally got the car running.... just
    it sounds pretty lumpy, and i'm not sure if its a timing issue. but.....
    i looked behind the car at the exhaust, and there's a fair bit of water chugging out the or the pipe and there's a decent amount of it as well. does this mean the head gasket hasn't sealed everything up properly?
    any info again would be appreciated
    good chance of it.
    have you done a compression test now youve got it back together.
    is it consuming coolant ?
    yeah consuming coolant... i'll do another comp test...
    got about 120 over all 4 cylinders.
    there's ton's of white smoke coming out of the exhaust. so i'm gonna assume when the head gasket went the head must have warped or cracked. spark plugs have a black powder on them.
    did you check the head for straightness and flatness ? and also use a penetrant dye to check for cracks.
  1. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 12:36 PM
  2. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 07:27 PM
