It gets igf from the coil.
Ive had similar problems, and one of the coils was rooted, but only under certain load, would drive perfect with no boost, would drive sometimes ok with boost.
Pull a lead off the plug and put a spare plug on it and earth each lead out, see if one is firing a weak spark, if it is, theres your problem.
O2 sensor, if youve reset the ecu and its still throwing the o2 sensor code, replace it, it could be causing the engine to run rich on cruise, which fouls the plug/s. When you give it a boot full, it burns the carbon off and continues on its merry way until next time.
No water temp sensor would think its cold all the time which puts in more fuel depending on how the ecu see's it.
