Hmm thanks takai. That means new manifold which is another thing i dont really wanna do. Might stick with the 20v quads and see how they go.
Thanks for all your help people
Heh, it wasnt quite John.
But it was a Sharpe who clinched Pole and a race win. Pics up soon from the day.
Back on topic, boltpattern for the Silvertop quads isnt anything like the EFI hardware ones. They are DCOE pattern.
N/A 3SGE KE70 on its way
thanks Takai,
Sory hach should of stated DCOE.
Also ask the guys at Injection Perfection, I believe they do them for the Gen II 3S also...Originally Posted by AEhachiroku
The 6 speed that came withe the SXE10 Altezza is the AZ6. It is the same box (in essence) as the S15 6 speed, the Miata 6 speed and the RX8 6 speed. The only car that seems to have any serious load issues with the AZ6 is the S15. The S15 is the heaviest of the vehicles that use the AZ6 and the SR20DET puts down the most torque of all those same vehicles.
What does all that mean??? Your AE86 is about 300 kilos(minimum) lighter than an S15, the n/a 3SGE has a MUCH lower torque peak than and SR20DET.
and it is torque load... not hp that destroys most gearboxes.....
You should have NO problems using the AZ6 with just about any 3SGE.....
its not an AE86, its a KE70.
same chassis and similar weights they may be, but use the correct terminology, so you dont confuse people.
Elmo.
you mean besides the fact its about 16hp more powerful and pisses off the crappy AFM to go MAP sensor?Originally Posted by AEhachiroku
JZZ20 1988 Soarer GT Twin Turbo 1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
Talk to RA45Celica. He does a nice manifold and quad throttle kit for the 3SGE. The results speak for themselves - 194 rwkW from an NA 2 litre.
is he using gen2 or 3 motors?Originally Posted by gianttomato
linden
He's using Black Top Beams 3S-GEs...Originally Posted by The Real Roadrunner
ahh, way different beasts but more in common with a gen3.
linden
gen2 3S-GE is MAP as well. you're thinking of the 3S-GTE maybe?Originally Posted by hamgatan
1992 MR2 GT turbo
2009 Lexus IS-F
Built Australia's first V6 MR2 >> Winner: "I'd Drive It" award - Toyfest '07
The ke70 is a light car, you do not need a W series box. a 3sge with a six speed behind it will be all the car will ever need for circuit. It is a short wheelbase so it is never going to be good at high speed. Keep it light and with an atmo engine that you can keep in the powerband and you will always do well even on your bad days!Originally Posted by AEhachiroku
Originally Posted by kingmick
Thats what my first thought was. But the car will be set up for drift aswell (drift being the main attention) with different spring rates at hand i was going to use it for curcuit aswell.
My main reason was because of the strain that drifting puts on a gearbox with the clutch kicks and hard shifting.
Also I have priced up a few things at work and i will be going turbo as i wont be able to push the power output i want on my budget.
Craig
